How to calculate Tension for a series of connected points?
  • Thread starter Thread starter Tyson1992
The discussion revolves around calculating tension in a series of connected points to simulate a rope for a game. Participants explore various models and approaches to maintain the maximum distance between points while accounting for forces and angles in a dynamic environment.
  • One participant describes a method for simulating a rope using a series of points that apply equal forces towards each other when they exceed a maximum distance.
  • Another suggests modeling the rope as a discrete chain of points with lumped mass and evaluating tension based on excess length, but acknowledges potential issues with elasticity.
  • Concerns are raised about the rope being stretchy, which could lead to unrealistic behavior, and the need for individual tension values for connected pairs.
  • A participant emphasizes that tension should be calculated to prevent further stretch rather than based solely on excess length.
  • Discussion includes the complexity of calculating tension when angles are involved, particularly when force is applied at different orientations.
  • One participant mentions that their trial model is too simplistic and does not account for forces applied orthogonally to the rope.
  • Links to external resources are provided for further exploration of rope modeling in game physics.
Participants express differing views on the appropriate modeling techniques for simulating tension in a rope. There is no consensus on a single method, and various approaches are debated throughout the discussion.
Some participants note limitations in their models, such as the assumption of massless springs and the effects of angles on tension calculations. The discussion highlights the complexity of accurately simulating rope behavior in a dynamic environment.
This discussion may be useful for game developers, hobbyists interested in physics simulations, and those exploring mathematical modeling of physical systems.
Tyson1992
TL;DR
Programming a rope for a game, need to apply tension force to pairs of points to keep them together and acting like a rope, figured out how to calculate a 4 point chain (3 "rope" pairs) but having trouble past that.
In an effort to simulate a rope for a game I'm making, I'm programming a series of points that, when a connected pair moves away from each other past their max distance, applies an equal force to both points towards each other to stay within max distance by cancelling out their relative motion away from each other.
When taut this would pull connected pairs past their max distance so I need to apply the appropriate force there as well all the way down the taut connections which increases the force for the preceding pairs.
I've figured out a formula to calculate a 4 point chain (3 "rope" connections) accounting for varying angles and masses, but am having trouble past that.
I can brute force it by writing out 2 different starting values and using how much it changed between them to calculate the correct answer but that would severely slow down the program.
I wasn't sure where to put this, what prefix to use, and don't know what to look up to find it cause I'm a hobbyist and first time poster. None of the tension examples I find have the ropes connected in series, just a static object to non-static object pairing, and the one time I found a series it was just a straight line.
Any help would be appreciated.
Technology news on Phys.org
Welcome to PF.
There are many approximations possible. They can be in 2D or 3D, and you can make it as accurate as you require.
I would model the rope as a discrete chain of points. Each point would have the same lumped mass, a position in 3D and a velocity in 3D. The rope would also have a total length when not under tension. For each time-step, evaluate the total length, compute the excess length, and from that the tension along the entire rope.
Then, for each time-step, evaluate the next position of each discrete point in the rope. For each point, calculate how it will be pulled by its two nearest points, the force acting to accelerate the point mass, update the velocity and its next position.
If I compute tension from excess length the rope will be stretchy, which I don't want, and in order to keep the individual pairs within a max distance they need individual tension values, otherwise a bunch of points can be on top of each other with one way off in the distance.
This is why, currently, every frame each pair is checked for max distance, then for velocity away from each other. For each pair that's taut and moving away from each other, I apply force towards each other, but I need to also apply tension to taut pairs down the chain so fixing one pair doesn't create the same problem elsewhere.
But that does not work.
Being elastic does not make a rope into a bungee cord. A tension supporting 1000 kg might only lengthen the rope by 1%.
The rope will move as a result of the ends being controlled in some way. Each segment of the rope will have a mass and a velocity that will control its trajectory.
If there is any tension in the rope, points along the rope should move to straighten the rope. That will pull in at sharp corners to make a more rounded loop. If there is no tension in the rope, the rope will keep moving, or lie there until it is pulled by the end of the rope.
1. Would you care to expand on "that does not work"
2. If I compute tension based on excess length, the tension(force) will increase with length over it's resting length, rather than applying force appropriate to preventing further stretch.
3. I'm not having any problems making a chain of points look like a rope, I'm trying to calculate the appropriate amount of force to apply to counter the points relative motion away from each other, so that when the rope is connected to objects it will pull on the object (and the object will pull on the rope) realistically.
4. I posted this in Calculus to get help with the math, it was moved here afterwards.
As you said yourself
Tyson1992 said:
[...I] am having trouble past that.
You are having trouble because you are not using an appropriate model. Let's start again.
Tyson1992 said:
TL;DR Summary: Programming a rope for a game, need to apply tension force to pairs of points to keep them together and acting like a rope,
To model a rope, use a series of massive nodes connected with massless springs (that only have force when extended, not when compressed).
But ropes ARE stretchy. If they didn't stretch they would be rigid bodies and rotate about their centre when you disturbed an end. You can make the modulus of the springs as high as you want to make the amount of stretch invisible to the user, but if you make it [Edit] infinite zero you can't do any discrete steps with it because ## \delta v = \dfrac k 0 \delta t = \infty ##.
The calculus forum is for help with analytic solutions to continuous functions. This is the right forum for discrete time step modelling.
Maybe this will clear things up.
TL;DR Summary: A straight series of points is effectively one point of all their mass combined, but how do angles in the chain of points change the tension?
When a series of points are connected in a line and acceleration is applied to one end, the tension can be calculated with just the masses.
For the example in the picture, I can calculate the tension by taking the relative acceleration between the moving point and the one it's connected to, and dividing by the total mass divided by the mass of one side of the acceleration and then divided by the mass of the other.
The result is .8 which when calculated out, shows every point moving moving .2 in the direction of acceleration. 1 m/s of a 1kg object is 1 newton of force, split between 5kg is .2 m/s, so that's correct.
In the other picture with 2 bends, how would one get 0.5365853654 for the starting tension?
I've put together a formula for a four point chain by essentially trial and error, but I don't really understand on a practical level how the angles are affecting it.
If there's an explanation for this in a textbook or website that someone knows about that'd be good too.
Your 'trial' model is too simple - you are only considering the situation where force is applied parallel to the direction of the last 'link'. A rope model needs to cope with a more difficult situation: an initially straight rope where force is applied orthogonally.
I have already given you one link (pun intended), if you don't like that one search the interweb for "game physics rope".
  • · Replies 17 ·
  • · Replies 31 ·
