How to calculate thermal exchange rate of Air?
To calculate the thermal exchange rate of air with varying humidity, it's essential to understand the heat capacity of humid air, which is influenced by the amount of water vapor present. The formula for specific heat capacity of humid air is C p = 1.005 + 1.82H, indicating that humid air requires more energy to heat than dry air, though the difference is minimal for typical conditions. While radiant heat absorption increases with humidity, other heat transfer mechanisms like conduction and convection are more significant in practical scenarios. For modeling purposes, investigating the infrared absorption spectrum of water vapor can provide insights into how much IR radiation is absorbed by air at different humidity levels. Accurate calculations will require integrating these factors to create a comprehensive graph of thermal exchange rates based on humidity.
AntiSpark
How would I calculate thermal exchange rate of Air for different amounts of humidity?
I'd like to create a graph to show how much radiant heat air would absorb, (at some temperature (10°C) changes depending on the humidity amount, 0 - 100%
Science news on Phys.org
Air in which setup?
Heat capacity changes as function of humidity, you can find formulas somewhere in the internet.
The difference is not significant for most ambient temperatures/humidities. In English units, it is about 1.082 BTU/CFM-F
For air at SAP at MSL ?
I've looked in the internet and haven't found it yet...
Are you looking for the Specific Heat Capacity of humid air?...
See reply 4...
http://physics.stackexchange.com/qu...s-how-much-time-is-needed-for-heating-the-air
The heat capacity of humid air is approximately given by:
C p =1.005+1.82H
where 1.005 kJ/kg°C is the heat capacity of dry air, 1.82 kJ/kg°C the heat capacity of water vapor, and H is the absolute humidity in kg water vapor per kg dry air in the mixture. So the specific heat capacity of humid air is greater than dry air and humid air will take more energy to heat by a given amount.
But the difference is quite small. I think 100% RH at 25C is only about 2% water, and if you need to heat the room the temperature, and therefore the water content, is presumably even lower. Taking the 2% water content only increases the specific heat by about 3.6%.
As I understand it, dry air is heated by radiation by some small amount and 100% humid air by a greater amount?
So I should be able to find or create a formula to make a graph showing the change from 0 to 100% humidity (or find a graph)?
You are forgetting about other, more important, heat transfer mechanisms like conduction and convection. In most practical situations, these will dominate over radiation.
If there are measurements or calculations to show how much they change (if any) depending on the amount of water vapor in the air? I'd take that as well.
But I was looking for how much the air would be warmed by IR radiation, and then that heat would be transferred by conduction and convection.
Seems as tho if I knew what amount of IR radiation would be absorbed by a sample of air that was 1% water vapor, that I would just double that to estimate it for 2% water vapor?
Sorry. I was confused about what you were asking for. For what you are asking, Google
Water Vapor Infrared Absorption Spectrum. Of course, this is just the basic property data. You still need to know how to apply the data in modeling atmospheric heating.
Chet
