- #36
sophiecentaur
- 7,007
I was thinking that's the next stage in implementing. If the amp has + and - supplies then obvs the bridge should be hung between them so the common voltage would be around zero. But if single sided amp then the same thing applies but with half of the 480Ω above and half below. I was wondering if the OP will get this all in one go.Baluncore said:4 * 120 ohm is the 480 ohm series resistor.
You must study the common mode input voltage range of the amplifier, to work out if the 120 ohm resistors should be placed above or below the bridge.
