How to create device that makes electrical discharge
10 replies · 3K views · last reply
David lopez
How do I build a device that creates
An electrical discharge between wires? I can build an oscillator. Do I
Connect an oscillator to a transformer and connect the transformer to a pair of wires?
You have a choice: build a van de Graaff generator, or -- more along the lines of your post -- study how a car ignition system generates a spark in spark plug.
If you are interested in the physics workings, post a more specific question in this or in a new thread.
Can you tell us more what you are trying to do? What configuration of wires do you mean - are they parallel or pointing their ends to one another? What size of spark do you want?
The device creates an electrical discharge.
The wires are parallel and the electrical
Discharge lasts as long as I hold a button down. How do I build that?
This circuit works well.
244192
and also a Jacob's Ladder
Photo of a Jacob's ladder: two bent metal wires on a wooden base form a V with an electric arc glowing purple between them, beside a grey metal box with wiring and terminals.
Tho seeing @David lopez 's other threads
I'm not sure he is really skilled enough to be working with high voltages ?
@berkeman
I assume that you want to make an arc through air? The problem with this is that it requires high voltage to do that. Unless you know a lot about electronic circuits, this can be quite dangerous. This is particularly true if you want a constant discharge. It is also hard to do from a technical, cost, and reliability perspective.
