How to derive the Poisson p.m.f.
  • Context: MHB
  • Thread starter Thread starter lamsung
    Derive Poisson
The discussion revolves around deriving the probability mass function (p.m.f.) of the Poisson distribution without referencing the binomial distribution. Participants express skepticism about the traditional derivation methods and explore alternative approaches, including axiomatic foundations of Poisson processes.
  • Exploratory, Debate/contested, Conceptual clarification
  • Some participants question whether deriving the Poisson p.m.f. from the binomial distribution truly addresses the origin of the Poisson distribution itself.
  • One participant suggests that the Poisson distribution can be viewed as an extreme case of the binomial distribution under certain conditions (low probability and high number of trials).
  • Another participant references a document that claims to derive the Poisson distribution without mentioning the binomial distribution, prompting further inquiry into its validity.
  • There is mention of three axioms of Poisson processes that could potentially lead to the derivation of the distribution.
  • Concerns are raised about the assumption that the probability of one event occurring in a short interval is proportional to the length of that interval, with a request for proof of this assumption.
Participants do not reach a consensus on the best method to derive the Poisson p.m.f. Some agree on the historical connection to the binomial distribution, while others propose alternative derivations and express uncertainty about the assumptions involved.
There are unresolved questions regarding the assumptions made in deriving the Poisson distribution, particularly concerning the relationship between event occurrences and time intervals.
lamsung
Can anyone derive the p.m.f. of Poisson distribution without mentioning the binomial distribution?
The binomial deriving method put lambda = np and finally the binomial p.m.f. become the Poisson one as n goes to infinity.
It seems that this is only proving that binomial distribution will approach the Poisson distribution as n goes to infinity, p goes to 0, and lambda stays constant, but it has nothing to do with deriving the p.m.f. of Poisson distribution.
So, the method has not solved my question that how does the p.m.f. of Poisson distribution come from.
I am doubtful for this.
I strongly suspect that Your consideration are derived from... Poisson Distribution -- from Wolfram MathWorld
Now 'Monster Wolfram' is a monster but that doesn't mean that all it writes is good!... the binomial distribution extablishes that the probability to have k 'good' results in n trials is...
$\displaystyle P_{n,k} = \binom {n}{k} p^{k}\ (1-p)^{n-k}\ (1)$
... and the Poisson distribution extablishes that if $\displaystyle \lambda$ is the mean number that a 'good result' occours in a unit time, then the probability to have k 'good results' in a unit time is... $\displaystyle P_{\lambda,k} = \frac{\lambda^{k}}{k!}\ e^{- \lambda}\ (2)$
In my opinion the best is to consider thye binomial and Poisson distribution as two different way to describe the reality and no more...
Kind regards
$\chi$ $\sigma$
I am not totally sure about this (still fairly sure) but I believe that historically the Poisson Distribution was derived from the Binomial Distribution. As you said it is an extreme case of a situation with a very low $p$ and a very high $n$, so using the formulas for the binomial distribution stops becoming the most efficient or best way to describe the distribution.
You seem to already know the algebra behind the derivation, but here it is in case anyone is interested. It's a bit long to type out here from scratch.
What about this document (PDF)? At least it does not mention binomial distribution.
Also, aren't there three axioms of Poisson processes from which the distribution can be derived?
So, can I say the following?
1. Poisson distribution is actually a (extreme case of) Binomial distribution.
2. If X ~ Po(lambda), then X ~ B(n, lambda/n) for a large n.
3. Using Poisson distribution but not Binomial distribution is due to efficiency of calculation. In other words, Poisson distribution is used to estimate the Binomial distribution provided the expectation (that is, np).
4. Suppose "success" is randomly distributed in a time interval (say, 3 unit time), disjoint regions are independent. Then lambda = number of success / 3. We can then use the Poisson distribution to find out the probability of number of success in a unit time, no matter how big (or how small) lambda is.
Thanks for sharing. I used a day to understand the document.
It almost solves my question, except, I am quite unsure about the first equation.
The equation states that the probability of one event occurs in a short interval (delta t) equals to lambda times delta t.
Intuitively, I agree. But I want a proof.
I believe this is an assumption from which you derive the Poisson distribution. There are other distributions for which it does not hold.
