How to Derive Velocity from Newton's Second Law?
9 replies · 3K views
Niles
Hi
In a book they state
[tex] \frac{dv}{dt} = a \quad \Rightarrow \quad v(z) = \sqrt{2a(z-z_{max})}[/tex]
I am trying to reproduce this. Here is what I have so far:
dv/dt = (dv/dz)(dz/dt) = v(dv/dz) = a
Since a is constant (I assume?), I get
[tex] \int vdv = \int adz \quad \Rightarrow\quad \frac{1}{2}v^2 + C = az [/tex]
Here C denotes a constant. What should I do from here?Niles.
what is z?
if [itex]\frac{dv}{dt} = a[/itex] then [itex]\int dv = \int a\ dt \ \rightarrow v = \int a\ dt[/itex]
Hi Niles! :smile:
æ
[tex] \frac{1}{2}v^2 + C = az [/tex]
erm :wink:
you're there! :smile:
tiny-tim said:
Hi Niles! :smile:
erm :wink:
Thanks. But how is it seen that C=2azmax?
You really might want to give us a lot more context on what you're doing. What is z? What is [itex]z_{max}[/itex]? If you tell us what the problem is, we can even tell you if the acceleration is constant.
It is from a book on how to slow atoms with a Zeeman slower. Here [itex]z[/itex] is the coordinate (longitudinal, along the magnetic field), and [itex]z_{max}[/itex] I believe is the longitudinal coordinate, where the velocity is zero. Sorry, I should have stated that at first.
Hi Niles! :smile:
Niles said:
… [itex]z_{max}[/itex] I believe is the longitudinal coordinate, where the velocity is zero.
v= 0 when z = zmax, so C = azmax :wink:
(the "2" would be for a different C)
Thanks. It is very kind of all of you to help me.Niles.
Is it correct that there are other ways to define C? E.g. as the initial velocity? In that case I would say that when z=0, then C=-0.5v2initial, so I get
[tex] 2az = v^2 - v^2_{initial}[/tex]
Yes, C can be anything, and can be re-named later.
We often get C in an integration, then we tidy it up, and we find we have something awkward like 2π/C …
so we call that C (or vo or zo) instead! :wink:
(in this case, I think it was C/2)
