How to design a CPU Cooler attached on an Aluminum Panel?
4 replies · 2K views
Mason_Jays
TL;DR
How to design CPU Cooler attached on Aluminum Panel ?
Im now drawing sheet metal blueprints, which has a feature like attachable of Commonly use of CPU Cooler.
The product that i want to attach is Cooler master Hyper T4.
is there any information about standard dimension for regular cpu cooler installation ?
Mason_Jays said:
Summary:: How to design CPU Cooler attached on Aluminum Panel ?
No. It varies with each CPU manufacturer and each CPU part number.
The cooler mfg. may have detail drawings available, but don't count on it.
The CPU mfg. often has drawings showing size and shape of the heat transfer area and the amount of force needed for adequate heat transfer, along with flatness requirements.
Even the CPU cooling fans, same brand, same part No., may have different mounting details and even reversed air flows.
It's the Wild West out there!
Good luck.
Cheers,
Tom
Good luck.
Cheers,
Tom
Really thanks for your great answer,
Thanks, yeah wild west here
Coolers will change. You will need to purchase a selection and look for common factors.
I think the best you will get is the Cooler Master data sheet;
https://www.coolermaster.com/catalog/coolers/cpu-air-coolers/hyper-t4/
Thanks for reply!
i noticed CPU cooler is attachable with each brands of cpu manufacturers standards
Like AMD AM1 FM1
and almost all of this was has 75x75mm length ..
so I'm trying to attach it together now
