mech-eng
- 825
- 13
Would you explain when the space should be left when backslash, \, is used?
For example some codes using backslash.
\ \displaystyle a=\frac{dv}{dt} \ : This one works good because there is space between the first two backslashes.
But if the space between the first backslash is removed the code does not work
##\\displaystyle a= \frac{dv}{dt} \##
And there should be a space between the last backslash and the last numbersign pair, ##.
Would you please explan this?
Thank you.
Thank you.
