How to determine the resistance in a electric heater
4 replies · 5K views
ronaldinho52
hallo everyone,
I have a problem which i can't solve. Does somebody know how to solve this problem?? The question is:
A 220 V electric heater has two heating coils which can be switched such that either coil can be used independently or can be connected in series or parallel, yielding a total of four possible configurations.
The warmest setting corresponds to 2000 W and the coolest corresponds to 300 W.
R1 > R2
Determine the resistance of R1 [in Ω].
regards
ronaldinho52 said:
hallo everyone,
R1 > R2
regards
What have you tried so far? How do you think you can approach it?
I've drawn four configurations;
1) two resistors parallel (R1 and R2) with a source voltage of 220 V
2) 1 resistor with a source voltage of 220 V
3) 1 resistor with a source voltage of 220 V
4) two resistors (R1 and R2) in series with a source voltage of 220 V
For each of these configurations I've computed the equivalent resistance and concluded that configuration 1 consumes the most power (so 2000 W) and config. 2 the least power (300 W). So for config. 1 I have 4 unknowns; R1, R2, I1, I2 and I have 3 equations; R1=U/I1 R2=U/I2 and finally P=(I1^2)*R1 + (I2^2)*R2. So I'm missing one equation to solve this problem and I do not know which one. I've also tried to use the last configuration and to relate these configs but I didn't get an answer that makes reason.
You just need to think a little more. For example, in the parallel circuit you know that [itex]V_1=V_2=V[/itex]. Thus,
[tex]P_p = V^2\left(\frac{1}{R_1} + \frac{1}{R_2}\right)[/tex]
And you already know the parallel circuit power consumption. Now, how about the single resistor circuit?
Wouldn't the least power occur when the net resistance is as large as possible? After all, P = V2/R.
