How to figure the voltage drop at different points along a circuit?
  • Thread starter Thread starter alan2023
    Voltage drop
This discussion focuses on calculating voltage drop in circuits with multiple loads at varying distances from the source. The primary formula used is VD = 2 * K * I * D / CM, where K is the K-Value for the conductor material, I is the current in Amperes, D is the distance in feet, and CM is the circular mils of the conductor. Participants emphasize the importance of considering upstream loads and suggest using circuit analysis techniques, such as solving simultaneous equations or utilizing SPICE software for complex scenarios. The conversation also highlights the differences between resistive and constant-power loads in voltage drop calculations.
  • Understanding of voltage drop calculations using the formula VD = 2 * K * I * D / CM
  • Familiarity with electrical circuit analysis and Ohm's Law
  • Knowledge of resistivity values for different wire gauges, specifically 12 AWG copper
  • Experience with SPICE software for circuit simulation
  • Research "Advanced voltage drop calculations for multi-load circuits"
  • Learn "How to use SPICE for electrical circuit analysis"
  • Study "The impact of load characteristics on voltage drop in AC circuits"
  • Explore "Simultaneous equations in electrical engineering for circuit analysis"
Electrical engineers, electricians, and anyone involved in designing or analyzing electrical circuits with multiple loads will benefit from this discussion.
  • #31
  • #32
It seems that actually it is a little more complicate.
The supply voltage is AC -as usual- and a driver AC/DC is provided in order to supply DC. Then 350 mA it could be the DC output [18-42 V].Let’s say Vdc=20 V Pdc=0.35*20=7 W.
In the interval of 115 to 125 Vac the LED current is 350 mA, but the Iac current is variable from 7/115=0.06087 to 7/125=0.056 A neglecting the losses and power factor.
If we consider 0.8 as power factor and 95% as efficiency we get
S=7/0.8/0.95=9.21VA and the currents Iacmin=9.21/125=0.07368 A and 36.87 degrees
Iacmax=9.21/115=0.08 A and 36.87 degrees.
  • #33
  • #34
The Electrician said:
@alan2023, are you still around?
From their profile page:
Last seen:
Yesterday, 10:03 AM
  • #35
Yes, I'm still here.
Without getting into all the nitty-gritty with the inner workings of an LED driver/fixture, I believe I'm starting to understand a bit more how the loads after a point on a circuit affect the voltage drop.
Looking at this original question from an electrical install perspective, my challenge to someone would be how to build a spreadsheet to plug in the distances and any other necessary values (voltage, wire size/resistance, amps, etc.). As an electrician, I use custom calculators usually in a spreadsheet to determine voltage drop, conduit fill, cable tray fill. I first understand the code/math requirements, then build the sheet/formulas.
Wanting to add the feature of multiple loads on the same circuit, (which is something very common, and voltage drop becomes an issue in long distance applications like exterior lighting), I believe I could just build the circuits including the wire as a resistor. So basically a combo series/parallel circuit. I know there are probably some great software tools you guys use, but I believe this could built in a spreadsheet and in doing so, I have a calculator to speed up future calculations, but also understand how it works.
Thank you all for the input, and I'm sorry if sent us down a rabbit hole:biggrin:.
  • #36
alan2023 said:
Looking at this original question from an electrical install perspective, my challange to someone would be how to build a spreadsheet to plug in the distances and any other necessary values (voltage, wire size/resistance, amps, etc.).
An estimate of the voltage drop can be made by assuming equal loads, distributed equally along the cable.
The number of loads is, n = 13.
The current drawn by each load is, i = 0.35 A.
The length of the cable is, d = 580 ft.
The resistance per unit length is, r = 1.6 milliohm/ft.
The average current is, i * n / 2.
The return resistance per unit length is, 2 * r.
The twos will cancel.
V drop = n * i * d * r = 4.2224 volt.
V far end = 120.0000 - 4.2224 = 115.7776 V.
  • #37
Here's how you could setup a spreadsheet using 7 columns, A,B,C,D,E,F,G. This setup assumes
a constant load current of .35 A per load.
Think of the length of wiring between loads as constituting a "zone". There are 13 zones also counting the distance from the 120V feed to the first load as a zone.
Column A is the distance of each load from the 120 volt feed.
Column B is the distance between loads, including the distance from the feed to the first load.
Column C is just a reverse integer sequence starting with the number of loads.
Column D is .35 times column C (element by element). These are the currents in each zone.
Column E is .0032 (2 * the resistance per foot of the wire used; the approximate value used here is
the one given by Berkeman. For other than 12 ga, use 2 * the value for that wire) times column D.
This is the voltage drop per foot of wire in a zone.
Column F is column B times column E (element by element). At this point the elements of column F are the voltage drops within each zone; they are the decrease in voltage from one load to the next.
Column G is the voltage at each load. Creating column G requires the use of a procedure. Start with 120V and subtract the first element of column F; this becomes the first element of column G. Now subtract the second element of column F from the just calculated first element of column G and this will be the second element of column G. Then subtract the third element of column F from the second element of column G and this will be the third element of column G. Continue this to the end.
  • #38
What application is that in the snip?
  • #39
It's just a math app that I used to format the data in columns, but I didn't do the calculations with it; I did the actual calculations on my HP50g calculator. I don't have Excel on my computer so I couldn't actually give an example of the calculations done in Excel, but I wanted to show what it probably would look like in Excel.
  • · Replies 22 ·
  • · Replies 28 ·
15K
