How to find acceleration from only initial and final velocity
To find the rate of deceleration for a snowboarder on flat snow after descending a slope, the coefficient of kinetic friction is essential, calculated as the force of friction divided by the normal force. The snowboarder's weight (60 kg) must be factored in to determine the force of friction at the bottom. A free body diagram helps visualize the forces acting on the snowboarder, including the normal force and friction opposing motion. The net force is not zero on flat ground, as the snowboarder decelerates due to friction. By applying Newton's second law (ma = net force), the acceleration can be calculated using the coefficient of friction and the normal force.
tooperoo
A novice snowboarder who weighs 60kg is sliding down a 10 degree slope at a constant velocity of 8 m.s^-1.
When they reach the bottom of the slope, they slow down due to the kinetic friction between the snowboard and the snow.
Find the rate at which the skier is de accelerating once they are on the flat snow.
I found the coefficient of kinetic friction (0.176), but how can you calculate the rate of de acceleration?
How did you find the coefficient of friction?
Coefficient = force of friction / normal force?
Is that not right?
Crap just realized I left out the snowboarders weight (60kg)
So what is the force of friction at the bottom then?
im sorry but i don't know how I would
You did that for the slope. Why can't you do it for the bottom?
Isnt there no net force acting at the bottom?
I found it on the slope because there was a force pulling it down the slope, but there isn't anything at the flat
The net force is zero on the slope, because the acceleration is zero. At the bottom, the snowboarder decelerates, which means the net force is not zero.
Start with the free body diagram.
My free body diagram shows the normal force and the weight arrows, and a force acting backwards, a force I am assuming is the kinetic friction acting on the snowboarder, slowing him down.
is that correct? where do i go from there?
Indeed, these are the forces acting on the snowboarder. You need to determine the acceleration.
I agree. I am just very unsure as to how i would go about that.
Thank you so much for your help so far!
As always, ma = net force. Decompose that into X and Y directions, and see where that gets you. This is actually simpler than what you did on the slope, there is no trigonometry involved.
The net force would be coefficient of friction derived above, multiplied by the Normal force, yes? (but the answer would be negative as it is pointing in the negative x direction?)
And then just solve for a?
Correct.
Thank you so much for your help! You're a life saver
13K
