How to Find R from Electric Charge Problem
35 replies · 4K views
kidi3
http://snag.gy/Zg3SO.jpg
At the moment is it question A
A)
I've realized that Force applied by F_31 + F_41 = F_21
SO I've writte this equation up but Mathmathica, says there is an errror, and gives me an incorrect result.
http://snag.gy/rQ2kz.jpg
Mathmatica says it should {{D -> -0.225008}, {D -> 0.185008}}
The correct answer should be 2,27cm.
No..
y -component must be zero since it is zero for q2
and the sum of q3 and q4 would negate the y component.
kidi3 said:
No..
Correct. So, you only need to work with the x components of the forces.
But aren't I doing it already?
I don't think so. It appears to me that on the left hand side of http://snag.gy/rQ2kz.jpg you are using the full magnitude of the forces F_31 and F_41, rather than their x-components.
Ahh.. so you want me to skip
d/cos([itex]\theta[/itex])
and just use d.. ?
and just use d.. ?
No, that part is correct, r = d/cosθ is the correct distance between charges 4 and 1. Draw a sketch showing the direction of the force F41. How would you express the x-component of F41 in terms of F41 and θ?
well the distance it moves is d.. so I have to write an expression for d..
So it would be rcosθ = d??
Sorry, but I don't understand. What is moving a distance d? I thought you were trying to find the distance D so that the net force on q1 is zero.
Your first equation which you derived looks good except it doesn't take into account that you want the x-components of the forces to add to zero. (You already know the y-components add to zero by symmetry.)
well q1 lies on a distance d from q3 and q4...
and isn't that distance given by r cos(θ)= d
where r is the Hypotenuse of the triangle`..
Yes. All of that is correct. So, your expression (d/cosθ)2 in the denominator of your equation is correct. :smile:
Force is a vector quantity. The equation F = q1q2/(4∏εor2) gives the magnitude of the force. You need to determine the x-component of the force vector. Again, a sketch of the forces will help.
... hmm would it then be
F_x = q1q2/(4∏εo(d))
Since both lies in a distance d?... or how..
No. Consider the x-component of F31. Can you use trigonometry or similar triangles to find Fx in the attached picture?
hmmm.. is it then cos(\theta)=r/x <=> x = cos(theta)/r
Ahh.. I see what you mean now..
My drawings weren't correct..
But by using youre drawing I see that Cos(theta) = F_x/F <=> F_x = Fcos(theta)
So the expression for F_X = (q1q2/(4∏εo(d^2))) cos(theta)
Hmm.. but i still get an incorrect answer.. :(
http://snag.gy/LDwAe.jpg
When i Tries to calculate D i get complex number..
It seems to work out ok. Note that you don't want to plug in a negative value for q3 since you have set up your equation to state that the magnitudes of the forces balance out.
D has to be 2,266 cm
But i get 1471,4 m...
Well, I get D = 1.92 cm. :frown:
If you go to your original equation, put in the cosθ factor on the left to get the x-component, and then simplify, see if you get
2q3cos3θ/d2 = q2/R2
where I let R be the total distance between 1 and 2.
If so, what do you get if you solve for R?
How do you get this ?
2q3cos3θ/d2 = q2/R2
But isn't what i have already done before..
Start with your original equation and put in a factor of cosθ on the left side to take care of getting the x-component.
Then, do you see that q1 cancels out as well as 4πεo?
For now, just let r stand for the distance between #3 and #1 charge. So, instead of writing d/cosθ on the left, just write r. And on the right side, let R be the total distance between #2 and #1. So, instead of writing D+d just write R. Can you state what the equation simplifies to?
These are my steps...
http://snag.gy/3oGJ5.jpg
The first equation is incorrect. I see you have the cosθ factor to get the x-component. Good. But for some reason you forgot to write (d/cosθ)2 in the denominator to represent r2.
