How to Find the Volume Needed for a Buffer Solution?
  • Thread starter Thread starter LeilaNami
    Buffer Volume
The discussion revolves around calculating the volume of 0.50M NaClO needed to prepare a buffer solution with 0.20M HClO to achieve a specific pH of 7.00. Participants explore the application of the Henderson-Hasselbalch equation and the relationships between concentrations and volumes in buffer solutions.
  • Homework-related
  • One participant attempts to use the Henderson-Hasselbalch equation but struggles with the calculation, leading to a frustration expressed over not arriving at the expected answer.
  • Another participant challenges the initial claim regarding the ratio [A]/[HA] = 0.35, suggesting that the correct approach involves calculating the moles of each component and dividing by the total volume of the solution.
  • A different participant elaborates on how to express the concentrations of NaClO and HClO in terms of the unknown volume of NaClO, emphasizing the need to account for the total volume of the buffer solution.
  • One participant acknowledges a misunderstanding regarding the Ka value for HClO, which contributed to their earlier confusion about the calculations.
  • Another participant confirms that the initial ratio of [A]/[HA] = 0.35 was indeed correct after further calculations, indicating a refinement of earlier claims.
Participants express disagreement on the initial calculation of the ratio [A]/[HA], with some asserting it is incorrect while others later affirm its correctness. The discussion remains unresolved regarding the exact volume of NaClO needed, as various methods and interpretations are presented.
Participants highlight the importance of using consistent values for Ka and the need to clarify the relationships between the components in the buffer solution. There are unresolved mathematical steps and assumptions regarding the volumes and concentrations used in the calculations.
LeilaNami
Finding volume needed for buffer (URGENT!)
What volume of 0.50M NaClO must be added to 0.20M HClO in order to prepare 500mL of a NaClO/HClO buffer with pH=7.00. Ka(HClO)= 3.5e-8
I'm using the H-H equation pH=pKa + log ([A]/[HA])
NaClO being A and HClO being HA
I tried doing it by method mentioned in another thread but I still did not get the right answer (answer is supposed to be NaClO = 61mL)
pKa= -log(3.5e-8) = 7.46
Using H-H found that [A]/[HA] = .35
mols A = mols HA (.35)
(mols A + mols HA)/.5 = .2
(.35 mols HA + mols HA)/.5 = .2
1.35 mols HA / .5 =.2
mols of HA = 7.4e-2 mols
mols A = (7.4e-2)(.35) = 2.58e-2 mols
.5= 2.58e-2/ L
L= 5.16e-2
mL = 51.6
Close but no cigar. What am I doing wrong?
I have a midterm tomorrow and I've been trying to solve this problem for 5 hours now and I feel like crying I am so frustrated. Please help!
I can't figure out where you got [A]/[HA] = .35, that's wrong.
To find the actual concentrations of [A-] and [HA] in the buffer solution, you need to find the moles of each and divide by the volume of solution, 0.500L. Since the final solution has a volume of 500mL, the volumes of the two solutions must add to 500mL or 0.500L. I solved it by letting x be the volume of NaClO solution and (0.500 - x) be the volume of HClO solution, then dividing each by 0.500mL solution to get the concentrations of [A-] and [HA]. Then plug everything into pH=pKa + log ([A]/[HA]) and solve for x, the volume of NaClO solution.
Thank you. At first I didn't understand but now I get it. I appreciate the help.
The concentration of NaClO in the final solution is the moles of NaClO divided by the volume of the final solution. Volume × molarity = moles of the solute in the original NaClO solution, but we don't know that volume; let that unknown volume be x. So x(0.50M NaClO) will give you moles of NaClO as I have in the numerator below.
The concentration of NaClO has changed in the new solution because you're adding HClO solution, but you know the final volume is 0.500L. Dividing the moles of NaClO by 0.500L gives you the concentration of NaClO, or [A]:
[tex][A] = \frac{\overbrace{x}^{volume~of~NaClO}\overbrace{(0.50M~NaClO)}^{molarity~of~NaClO}}{0.500L~solution} \rightarrow\frac{moles~of~NaClO}{divided~by~volume} = concentration~of~salt~or~[A][/tex]
We will do something similar for the concentration of HClO. Volume × molarity = moles, so we need to express the volume somehow. The two volumes of solution must add to 0.500L and we already let x be one of the volumes, so the volume of the other solution has to be (0.500L - x).
[tex][HA] = \frac{\overbrace{(0.500L - x)}^{volume~of~HClO}\overbrace{(0.20M~HClO)}^{molarity~of~HClO}}{0.500L~solution}\rightarrow\frac{moles~of~HClO}{divided~by~volume} = concentration~of~acid~or~[HA][/tex]
Now to get [A]/[HA]:
[tex]\frac{[A]}{[HA]} = \frac{\frac{x(0.50)}{0.500}}{\frac{(x - 0.500)(0.20)}{0.500}} = \frac{0.50x}{0.20(x - 0.500)}[/tex] since the 0.500 in the denominators cancel each other.
Now that you have [A] and [HA], plug them and pH and pKa into the equation and solve for x.
[tex]7.00 = 7.46 + \log\left(\frac{0.50x}{0.20(x - 0.500)}\right)[/tex]
Strong words :wink:
After some calculations you got to the point where you have shown that
Bohrok said:
[tex]\frac{[A]}{[HA]} = \frac{0.50x}{0.20(x - 0.500)}[/tex]
and then you put it into Henderson-Hasselbalch equation:
it follows that
[tex]\frac{[A]}{[HA]} = \frac{0.50x}{0.20(x - 0.500)} = 10^{7.00-7.46} = 0.35[/tex]
so initial part of the Leila's calculations was correct.
I know what I did wrong, I was using another Ka value for HClO I found online that was different; I thought at first that might have been the problem. No wonder I didn't get 0.35 :blushing:
Happens all the time :wink:
  • · Replies 20 ·
  • · Replies 16 ·
