How to get (v1+v2)/n for odd n with minimum resistors
  • Thread starter Thread starter LongApple
    Minimum Resistors
The discussion focuses on solving the problem of obtaining the output voltage (V1 + V2) / n for odd n using only resistors and two voltage sources, without the use of operational amplifiers. Participants suggest using a resistor network where each input voltage connects to the output through a resistor valued at k * r, with r being an arbitrary scale value, such as 1k ohm. The consensus is that for odd n, at least three resistors are necessary, except in the case of n = 1, where stacking voltage sources could reduce the requirement to two resistors.
  • Understanding of resistor networks and voltage dividers
  • Familiarity with basic circuit theory and Ohm's Law
  • Knowledge of series and parallel resistor combinations
  • Ability to analyze circuits without operational amplifiers
  • Research resistor network design for averaging multiple voltage inputs
  • Learn about voltage divider circuits and their applications
  • Explore the implications of using only passive components in circuit design
  • Investigate common earth grounding issues in circuit analysis
Electrical engineers, circuit designers, and students tackling problems involving voltage averaging and resistor networks without operational amplifiers.
LongApple
Member warned about posting homework without the template
For example, the simplest case n=3 I am even stuck on much less the general problem we can start with that and evidently it may be able to be soled with only two or three resistors if you are clever
Also we are not allowed to use op amps only resistors and we are given two voltage sources.
My first plan was to use two resistors to get the average of the voltages and then connect that node with the average to more resistors- however, we can't use op amps and therefore I can't isolate that average of the voltages. I imagine we need to come up with the 1/3 or the 1/5 using a more clever and indirect way
You are assuming V1 and V2 are equal. Why not just put V1 and V2 in series with a 2 ohm/1 ohm divider?
Seems to be one of those problems where you have k voltage inputs.
And you want an output voltage = Sum( V1 ... Vk) / n.
This general problem turns out to have a very simple solution. But it can take some people a long time to reach it.
Since this has now transmuted into a homework problem I won't give you the answer.
The first thing to realize is that the input voltages are all unknown, but must all be treated equally.
Start by selecting an arbitrary scale value of resistance, say r = 1k ohm.
Connect each of the k inputs to the output through a resistor having a value of k * r.
Does that meet the above requirement of treating all equally ?
Now, to get an output voltage that is 1/n of the average input, you will add one resistor to ground.
How might you work out the value of that resistor ?
Good thinking! :woot: Unfortunately, the problem statement doesn't assure us there is not a common earth. :nb)
V1 + V2 =N*SomethingOdd ? ... Well, anything_even -1 is odd.
Without an op-amp, the student, who now appears to have withdrawn, cannot use the negative resistance of an amplifier.
It is also odd that n must be an integer.
The reason why odd and integer were specified may suggest that all resistors needed be composed of series / parallel combinations from the same batch of resistors having the same value.
Voltage divider has been suggested
R1/(R1+R2) = 1/N ?
but i think in pictures , and since this is homework forum won't post my circuit
said i wouldn't
Maybe, but it's very common in lab supplies and in simulations and with batteries, etc., to stack voltage sources in series...
Odd might be a red herring... ?
Sure, either solution should be fine. The solution with the fewer limitations should attract more marks.
Now, let's turn that advice around. "... and evidently it may be able to be solved with only three resistors, or two if you are clever"
That really only changes the punctuation and implied brackets.
If the voltages could be summed by stacking then it would never need more than two resistors. (You are clever).
If the voltages are all ground referenced inputs, then for odd n, three resistors are necessary in all but the one case of n = 1. That cannot be solved without stacking.
and it'd work for any N .ge. 1, even or odd, integer or non-integer.
  • · Replies 17 ·
