How to integrate this integral?
5 replies · 2K views · last reply
CalcYouLater
Perform the following integration:
[tex]\int_{0}^{\sqrt{2}h}\frac{x}{\sqrt{h^2+x^2-\sqrt{2}hx}}dx[/tex]
The solution (via wolframalpha.com) is:
[tex][\sqrt{h^2+x^2-\sqrt{2}hx}+\frac{h}{\sqrt{2}}ln(2(\sqrt{h^2+x^2-\sqrt{2}hx}+x)-\sqrt{2}h)[/tex]
Evaluated from 0 to sqrt(2)h
Here is the link: http://www.wolframalpha.com/input/?i=x/[(h^2+x^2-(2^(1/2))*x*h)^(1/2)]
I immediately looked at a substitution and an integration by parts. They left me worse off than before. Then, I went to wolframalpha in order to see how to do it. They could not show any steps. I am not sure how to integrate this by hand. Any advice?
If this is an integral that you simply look up in a table, could someone point me to the methods used (no matter how complex) that will solve this?
Thanks for reading.
First complete the square in the denominator:
[tex]x^2- \sqrt{2}hx+ h^2= x^2- 2\sqrt{2}hx+ \frac{h^2}{2}- \frac{h^2}{2}+ h^2[/tex]
[tex](x- \frac{\sqrt{2}}{2}h)^2+ \frac{h^2}{2}[/tex]
Make the substitution
[tex]u= x- \frac{\sqrt{2}}{2}h[/tex]
Thanks for reading.
Try completing the square under the radical. Then do a substitution.
[tex]\sqrt{h^2+x^2-\sqrt{2}hx}}\ =\ \sqrt{x^2-2\frac{h}{\sqrt{2}}x+\frac{h^2}{2}-\frac{h^2}{2}+h^2}\,}[/tex]
[tex]=\sqrt{\left(x-\frac{h}{\sqrt{2}}\right)^2+\frac{h^2}{2}\,}[/tex]
Thank you, HallsofIvy and SammyS.
Following HallsofIvy's suggestion for the value of u, I did the following:
[tex]\int_{0}^{\sqrt{2}h}\frac{x}{\sqrt{h^2+x^2-\sqrt{2}hx}}dx\rightarrow{\int\frac{u+\frac{\sqrt{2}}{2}h}{\sqrt{(u^{2}+\frac{h^{2}}{2})}}du\rightarrow{\int\frac{u+\frac{\sqrt{2}}{2}h}{\sqrt{(u-\frac{\sqrt{2}}{2}h)(u+\frac{\sqrt{2}}{2}h)}}du[/tex]
Then:
[tex]{\int\frac{u+\frac{\sqrt{2}}{2}h}{\sqrt{(u-\frac{\sqrt{2}}{2}h)(u+\frac{\sqrt{2}}{2}h)}}du={\int\sqrt{\frac{u+\frac{\sqrt{2}}{2}h}{u-\frac{\sqrt{2}}{2}h}}du[/tex]
Here is where things began to get circular. I tried integration by parts two times in succession, this lead me back to the original integral (the last one listed above). It seems I either over-complicated the situation, or missed a key step.
[tex]u^{2}+\frac{h^{2}}{2}\neq\left(u-\frac{\sqrt{2}}{2}h\right)\left(u+\frac{\sqrt{2}}{2}h\right)[/tex]
[tex]\left(a+b\right)\left(a-b\right)=a^2-b^2\neq a^2+b^2[/tex]
Break the integrand up:
[tex]\int\frac{u+\frac{\sqrt{2}}{2}h}{\sqrt{u^{2}+\frac{h^{2}}{2}}}\ du=\int\frac{u}{\sqrt{u^{2}+\frac{h^{2}}{2}}}\ du\ +\ \left(\frac{\sqrt{2}}{2}h\right)\int\frac{1}{\sqrt{u^{2}+\left(\frac{h}{\sqrt{2}}\right)^2}}\ du[/tex]
The first can be done by the substitution [tex]t= u^2+\frac{h^2}{2}\,,[/tex] or even better, [tex]t= \sqrt{u^2+\frac{h^2}{2}}\,.[/tex]
The second by the substitution [tex]u= \frac{h\,\tan(v)}{\sqrt{2}}\,.[/tex]
Thanks SammyS! After a bit I was able to work out the answer as:
[tex]\sqrt{x^2-\sqrt{2}hx+h^2}+\frac{\sqrt{2}h}{2}[ln((\frac{\sqrt{2}h}{2})(\sqrt{x^2-\sqrt{2}hx+h^2}+x-\frac{\sqrt{2}h}{2}))][/tex]
Which after evaluating from 0 to sqrt(2)h gives me:
[tex]\frac{\sqrt{2}h}{2}[ln(1+\sqrt{2})-ln(\sqrt(2)-1)][/tex]
Which is the same result as listed in the initial problem. Thanks again! It was good to sharpen my integration skills.
