How to measure angle of rotation of sucrose
  • Context: Undergrad
  • Thread starter Thread starter barca12345
    Angle Measure Rotation
To measure the angle of rotation of polarized light by a sucrose solution, utilize a polarimeter, which requires two polarizers and a glass tube to contain the solution. The ends of the tube should be sealed with glass plates to avoid interference from plastic materials. By comparing the intensity of light passing through the empty tube and the sucrose solution, one can determine the rotation angle by adjusting the polarizers to achieve maximum or minimum intensity.
  • Understanding of polarimetry principles
  • Knowledge of light polarization and its effects
  • Familiarity with sucrose solutions and their optical properties
  • Experience in setting up optical experiments
  • Research the design and operation of polarimeters
  • Learn about the optical rotation of sucrose solutions
  • Study the effects of different materials on light polarization
  • Explore advanced techniques for measuring optical rotation
Students and researchers in chemistry and physics, optical engineers, and anyone interested in measuring optical properties of solutions.
barca12345
Hi all!
Supposed I have my solution of sucrose, my light source, my polarizer.
I shine my light source on my polarizer and plane polarized light passes through my solution, how then do I measure the how much my solution has rotated my polarized light by?
And also, what kind of container should I place my solution in?
Thanks!
You need two polarizers and a tube (material not important). Just fill in the sucrose solution into the tube whose ends you may close by glueing glass plates (not plastic, as it will probably act as a polarizer, too). Comparing with the empty tube, you will have to rotate the polarizers on both sides so as to get maximum (or minimum) intensity. Google "polarimeter".
  • · Replies 37 ·
  • · Replies 16 ·
