How to picture the magnetic vector potental A
The discussion revolves around the nature and interpretation of the magnetic vector potential \( A \) in relation to the magnetic field \( B \). Participants explore theoretical concepts, mathematical representations, and implications in both classical and quantum physics contexts.
  • One participant questions how the vector potential \( A \) can exist outside regions where the magnetic field \( B \) is zero, contrasting it with the electric potential derived from the electric field \( E \).
  • Another participant explains that the curl of \( A \) corresponds to \( B \), suggesting that \( A \) circulates around points of nonzero \( B \) and can be represented in various forms through gauge choices.
  • A different participant emphasizes that while \( A \) is often viewed as a mathematical convenience in classical electromagnetism, it plays a significant role in quantum physics, where particles can be influenced by \( A \) even in regions of zero \( B \), citing the Aharonov-Bohm effect as an example.
  • One participant clarifies that \( A \) is not expressed solely in terms of \( B \) due to its gauge dependence, noting that different forms of \( A \) can yield the same \( B \) field.
  • Another participant finds the Lorenz gauge helpful for visualizing \( A \) as independent scalar potentials corresponding to current components, although this approach complicates the interpretation of the Lorentz force direction.
Participants express differing views on the physicality and interpretation of the vector potential \( A \). There is no consensus on whether \( A \) should be considered a physical field or merely a mathematical tool, and the discussion remains unresolved regarding its implications in classical versus quantum contexts.
Participants highlight limitations in understanding \( A \) due to its gauge dependence and the varying interpretations across different physical frameworks. The discussion reflects a range of assumptions about the nature of potentials and fields.
si22
whats a good way to picture the vector potental A in terms of B & like what exactly is A & how does it even exist outside a torus where B & etc =0
for example its easy to see the electric potential uses the electric field E like E*ds & its quite obvious,
wheras how does A not even contain the B field
also why is A sometimes said to not even exist or is just a paper shortcut when it actualy seems to work or exist in some way. thanks
Since the curl of the vector potential A is equal to the magnetic field B, a good way to think of it is that A circulates around any point where B is nonzero--its net circulation around a point gives the B field at that point, according to the right-hand rule. It is important to remember though that you can always write down different A's to produce the same B field--this is called choosing a gauge. For example, a uniform B field in the z direction could be represented by any of the following:
A = -By i
A = Bx j
A = -By/2 i + Bx/2 j
where i is the unit vector in the x direction, and j is the unit vector in the y direction, and B is the magnitude of B.
If you plot these, you will see that they all look quite different, but they all circulate around in a similar fashion.
In classical E&M, the B field is the measurable quantity, so A is said to just be a mathematical convenience. However, in quantum physics, particles can be affected by magnetism even if they never pass through a region of nonzero B--instead they directly interact with A. A good example is the Aharanov-Bohm effect: http://en.wikipedia.org/wiki/Aharanov-Bohm_effect
What do you mean the vector potential ##A## isn't given in terms of the magnetic field ##B##? ##\nabla \times A = B## so you can picture it in terms of the usual geometric interpretation of the curl (think of the vorticity of velocity fields of fluids). The reason classically that ##A## is said to simply be a purely mathematical field (and not a physical field) is because it is not a gauge invariant quantity. I can take ##A \rightarrow A + \nabla \varphi## and I will still get the same physical magnetic field ##B## i.e. ##\nabla \times (A + \nabla \varphi) =\nabla \times A##.
I've found it helpful to look at the vector potential in the Lorenz gauge -- where each component of the vector potential acts like an independent scalar potential for the corresponding current component...so you can imagine each infinitesimal current-element in the <x, y, z> direction as a source for a corresponding 1/r A field whose vector points in the same <x, y, z> direction. What you lose, though, is the ability to see the direction of the Lorentz force by just comparing the directions of two vectors at a single point.
  • · Replies 54 ·
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 42 ·
  • · Replies 16 ·
