How to Position an Object for a 2.5x Inverted Image with a Concave Mirror?
The discussion revolves around determining the position of an object in front of a concave mirror with a focal length of 10 cm to create an inverted image that is 2.5 times larger than the object. The problem involves concepts from optics, specifically related to mirrors and magnification.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the relationship between object distance, image distance, and magnification using the mirror formula and magnification equation. There are discussions about the sign conventions for focal length and distances in optics, with some participants questioning the assumptions made regarding these conventions.
The discussion is ongoing, with participants providing insights into different sign conventions used in optics. There is acknowledgment of differing interpretations based on regional educational practices, and some participants are seeking clarification on these conventions.
There are mentions of different sign conventions, specifically the Gaussian sign convention and a regional convention from India, which may affect the interpretation of the problem. The original poster's choice of positive object distance is noted as a point of confusion among participants.
ichilouch
Where do you put an object in front of a concave mirror of focal length 10cm to produce an image that is inverted and 2.5 times greater than the object?
[itex]\frac{1}{f}[/itex]=[itex]\frac{1}{P}[/itex]+[itex]\frac{1}{Q}[/itex]
Where:
Q=Image distance from mirror
P=Object's distance from mirror
f = Focal length
m=[itex]\frac{-Q}{P}[/itex]
m=Magnification
m=-2.5
Q=-mP ------ (1)
[itex]\frac{1}{f}[/itex]=[itex]\frac{1}{P}[/itex]+[itex]\frac{1}{-mP}[/itex]
P=[itex]\frac{f}{\frac{m}{m-1}}[/itex]=[itex]\frac{0.1}{\frac{-2.5}{-2.5-1}}[/itex]
P=0.011 meter
Focal length of a concave mirror is to be taken negative.
No it isn't. The most common sign convetion - the Gaussian sign convention - which is used by most elementary optic texts has concave mirrors with positive focal distance and convex mirrors with negative focal distance.
P=0.011 meter
[itex]\frac{0.1}{\frac{-2.5}{-2.5-1}}[/itex] is not 0.11 m.
ehild
ehild
Sorry, Its 0.14m
That is correct.:smile:
ehild
Oh sorry! I didn't notice that the Poster took object distance as positive. Here in India, we have a different sign convention. According my textbooks, sign of the distance with respect to the pole of the mirror depends on whether the distance is parallel or antiparallel to the incident light ray. If the 'vector' from pole to focus is parallel to the light ray, it is taken positive and negative otherwise.
First time a hear of this convention. Could you elaborate?
I have posted an image of the sign convention.
That seems to be the Cartesian sign convention which is the second most common sign convention as far as I know. I thought you were talking about some other convention.
