How to predic the possible values of Lx
  • Thread starter Thread starter EliotHijano
EliotHijano
Hello, I would like to ask you something about angular momentum in quantum mechanics;
If I know that when t=0, my wave function is \Psi=\Upsilon^{m}_{l} and l=3 and m=0, How can I calculate the probability of getting the value \hbar meassuring L_{x}?
Why not perform a passive rotation of 90° around the y-axis. Under this rotation, the |3,m> states transform to the |3,m> states in the x-basis. But you get them expressed in terms of the z-basis. So, you then see how |3,1> in the x-basis is expressed in terms of the |3,m> states in the z-basis and you can then read-off the inner product.
Thank you Count Iblis, that was the answer, I did it before reading this, but thank you anyway!
the answer was 3/16 If i remember correctly.
Maybe it is usefull for anybody to see the process. Look at the pdf.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
