How to prove: Uniqueness of solution to first order autonomous ODE
The discussion centers on proving the uniqueness of solutions to the first-order autonomous ordinary differential equation (ODE) defined by the equation \(\dot{x} = f(x)\) with initial condition \(x(0) = x_{0}\), where \(f\) is continuously differentiable (\(f \in C^{1}(\mathbb{R})\)). Participants argue that if \(f(x_{0}) \neq 0\), a unique solution exists in an interval around \(x_{0}\). The conversation highlights that while solutions may not be unique when \(f\) reaches zero, the condition \(f \in C^{1}(\mathbb{R})\) ensures the existence of unique solutions in defined intervals.
  • Understanding of first-order autonomous ordinary differential equations (ODEs)
  • Familiarity with the concept of uniqueness in solutions of differential equations
  • Knowledge of continuous differentiability, specifically \(C^{1}(\mathbb{R})\)
  • Basic integration techniques applicable to separable equations
  • Study the existence and uniqueness theorems for ODEs, particularly the Picard-Lindelöf theorem
  • Explore the implications of continuous differentiability on the behavior of solutions
  • Investigate the role of separability in solving first-order ODEs
  • Examine cases where \(f(x) = 0\) and the impact on solution uniqueness
Mathematicians, students of differential equations, and anyone interested in the theoretical aspects of ODEs and their solutions.
Jösus
Hello!
I would like to prove the following statement: Assume [itex]f\in C^{1}(\mathbb{R})[/itex]. Then the initial value problem [itex]\dot{x} = f(x),\quad x(0) = x_{0}[/itex] has a unique solution, on any interval on which a solution may be defined.
I haven't been able to come up with a proof myself, but would really like to see a direct proof, not using too serious tools from a sophisticated theory of ODE's. I would very much appreciate it if someone could help me out.
Thanks in advance!
Hello Jösus! :smile:
Jösus said:
… the initial value problem [itex]\dot{x} = f(x),\quad x(0) = x_{0}[/itex] has a unique solution, on any interval on which a solution may be defined.
So you can assume that there is a solution g, and you have to prove that there can't be two solutions, g and h.
So suppose dg/dx = dh/dx = f.
Then … ? :wink:
Correct me if I'm wrong, but shouldn't the equation read [itex]dg/dt = f(g(t)), \quad dh/dt = f(h(t))[/itex], and thus there would be no apparent reason for these derivatives to be equal?
I have thought about it some more, and found that if [itex]f(x_{0}) \neq 0[/itex] then there is an interval containing [itex]x_{0}[/itex] on which a unique solution exists (the equation is separable, so a simple integration trick works). When f reaches a zero in finite time, so that the inteval on which this solution is defined is cut off there may be extensions to the solutions beyond the problematic points. If, say, [itex]f(a) = 0[/itex] then setting [itex]x(t) = a[/itex] for t larger than (or smaller than if a is on the right of our starting point) will, I believe, do the trick. It is solutions of this type that aren't always unique, but with the requirement [itex]f \in C^{1}(\mathbb{R})[/itex] it should work. Any new ideas?
  • · Replies 0 ·
  • · Replies 28 ·
