How to reach 2,000 Fº at home?
  • Thread starter Thread starter eduardojgg91
    Home
To reach 2,000°F at home for blacksmithing, using charcoal or wood as fuel is recommended, along with a system for adding oxygen, such as bellows. Learning blacksmithing is best done in person with an experienced individual rather than online, due to the skill's complexity and potential dangers. Local blacksmithing organizations can provide valuable resources and guidance. Additionally, using high-temperature torches can help achieve the necessary heat, with options available for around $70 each. Setting up a proper ventilation system is crucial for safety and effectiveness in creating a smelting chamber.
eduardojgg91
Hello everybody.
I wonder how can I reach 2,000 Fº at home, the fuel. The thing is I want to shape, and form some metal pieces. But I first need to reach 2k Fº to start shaping the metal. It is a bit thick so I can't work it in cold.
I want to work with Blacksmithing here at my backyard. I just don't know what materials I need to start with. I don't know nothing about this.
Thanks!
2000º F is about 1300 K, which corresponds to a slightly orangish red color. I would guess that you could use charcoal or wood or anything else that would produce coals and that the more important thing will be to have some bellows or other system for adding oxygen to the coals. Of course, that is a completely uninformed guess so take it for what it is worth which probably isn't very much.
The best way to learn about blacksmithing is to find another person who already knows how to do it. You should find someone in person, rather than online, so they can show you what is involved.
A skill like blacksmithing would be extremely difficult, and potentially dangerous, to try learning over the internet.
If you google "blacksmith" and your state/province/city, you might find a local organization that you could contact. Something along the lines of this:
http://njba.abana-chapter.com/
Good luck!
Depends on your budget. I just did a little random digging and found a few torches here: http://www.bernzomatic.com/quickfire-hand-torch/quickfire-faqs.aspx. These cost about $70 per pop, but it says they go to 3600 deg F. You could get 2 of these guys, and an outdoor wood stove, drill a few holes in the stove and then point these guys into the chamber. Set up a ventilation flow top to bottom and you've probably got a nice little smelting chamber going.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
