How to rigorously motivate the following formula
  • Thread starter Thread starter Kurret
    Formula
Kurret
I have encountered the following formula a couple of times (always in a physics context, of course..)
\int_{0}^\infty \frac{dt}{t}e^{-tx}=-\log x
Formally one can "derive" this formula by noting that
\log x=\int \frac{dx}{x}=\int dx \int_0^\infty dte^{-xt}=-\int_0^\infty \frac{dt}{t}e^{-xt}
But the t integral obviously diverges. So there must be some regularization of this integral but this is never explained (and sometimes they write that the integral is from ##0^+## instead of 0, whatever that means).
Mathematics news on Phys.org
From a mathematical point of view, this doesn't look right. logx=\int_1^x \frac{du}{u}. Therefore the final integral should be:
-\int_0^{\infty} \frac {dt}{t}(e^{-xt}-e^{-t}), which is convergent.
Set ##x = 1## and you get:
\int_{0}^\infty \frac{dt}{t}e^{-t}=0
Which can't be right.
In any case, the LHS is positive and the RHS is negative for ##x > 1##.
I agree with everything you are saying, but this is a formula I see quite often but I never understand what it means due to these issues. Just to throw in an example, look at page 5 before equation 1.11 of the following paper
http://arxiv.org/pdf/0804.1773v1.pdf
I don't see the relation between the formula that uses a sum, an additional integral, some function K and other things but no exponential, and your function (which has been shown to be wrong).
Try offering it pizza. Always works for me :smile:
The additional sum is the only difference. Just substitute the equation just before to get rid of the inner three dimensional integral.
I am not making this up, I have seen this divergent integral popping up several times without any comments about the obvious fact that it is wrong...
