How to show this mathmatically?
  • Thread starter Thread starter Kaldanis
To show that A \ B = ∅ if and only if A ⊆ B, one must demonstrate that if A is a subset of B, then removing elements of A that are also in B results in an empty set. The reasoning is that if every element of A is contained in B, then no elements remain when A is subtracted from B. Conversely, if A \ B is empty, it indicates that there are no elements in A that are not also in B, confirming that A is indeed a subset of B. The mathematical expression can begin with the definition of subset and proceed to show the implications clearly. This establishes the equivalence between the two statements.
Kaldanis
Let A and B be sets.
Show that A \ B = ∅ if and only if A ⊆ B.
I think this means that A is a subset of B, therefor if I remove all the elements of A that are in B, A would end up being empty (or ∅).
How do I write this mathmatically or is the above sentence acceptable?
Show that A \ B = ∅ if and only if A ⊆ B.I think this means that A is a subset of B, therefor if I remove all the elements of A that are in B, A would end up being empty (or ∅).
You would start with something like, A is a subset of B implies for all x in A, x is in B. ...
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
