MHB Can This System of Equations Be Solved for Variables x, y, z, and Any?
  • Thread starter Thread starter mrk79blr
The discussion focuses on solving a system of equations involving variables x, y, z, and an additional variable "Any." Participants suggest initially setting "Any" to zero to simplify the equations into a linear form. After simplification, three linear equations are derived, but the values for x, y, and z appear to be zero, which leads to confusion regarding the validity of the solution. A suggestion is made to substitute "Any" with a variable K instead of zero to explore different solutions. The conversation emphasizes the importance of proper substitution and manipulation of equations to find valid solutions.
mrk79blr
329x / (329x + 276y + 340z + 332Any) =0.5
276y / (329x + 276y + 340z + 332Any) =0.1
340z / (329x + 276y + 340z + 332Any) =0.2
We need to figure x,y,z and Any value. "Any" don't have any equation, so it can be any value.
Anyone can help me how to solve the above problem?
Thanks
Mathematics news on Phys.org
Re: How to solve this rquation
Don't worry about the Any, for the moment take Any to be zero. Then you have 3 linear equations in 3 variables and I presume that you are studying solving systems of linear equations.
It is non linear equation
It looks linear to me. Why do you think that it is non-linear?
Sorry it is linear equation only, But when i convert all the variables are coming as zero. Plz advice what i am doing wrong.
I consider Any as zero. So I am ignoring the same from the above equation.
If I simply the equation I will get following result
equation 1
329x / (329x + 276y + 340z) =0.5
329x=0.5 * (329x + 276y + 340z)
329x=164.5x + 138y + 170z
329x-164.5x-138y-170z=0
164.5x-138y-170z=0
equation 2
276y / (329x + 276y + 340z) =0.1
276y= 32.9x+27.6y+34.0z
-32.9x+248.4y-34.0z=0
equation 3
340z / (329x + 276y + 340z) =0.2
340z=65.8x+55.2y+68z
-65.8x-55.2y+272z=0
After simplify the 3 equation i will get 3 equations as follow
164.5x-138y-170z=0
-65.8x-55.2y+272z=0
Now x,y,z value is zero It will solve the above 3 equations. But If i set the values as zero in the actual equation it will not solve
So I am sure i have made some mistake. Please advice me.
Thanks
So you can solve the given system of equations? I have. What is the answer?
Are you saying that you want to design an algorithm to solve any system of linear equations? You can do this by manipulating matrices.
- - - Updated - - -
Instead of setting Any to zero, perform a substitution. Substitute K for 332Any.
for x, the answer is x = -45K/10*329
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
