How to Use the Sudoku Module in Ruby to Solve Puzzles?
  • Thread starter Thread starter sean1234
    Program Ruby
The discussion centers around a Ruby code snippet intended to solve Sudoku puzzles, which was saved as "foo.rb" but failed to execute when the user attempted to run it in the terminal with the command "ruby foo.rb." The code defines a module called Sudoku, which includes a Puzzle class that handles the initialization and validation of a Sudoku grid, as well as methods for solving the puzzle. Key issues highlighted include the need to properly invoke the module by creating a separate file, such as "sudoku_solver.rb," and using the correct command to run it with an input file. The original code snippet is noted to be from "The Ruby Programming Language," and the importance of reading the comments within the code is emphasized, particularly the instruction to require the module and provide input via the command line. This indicates that the user may have misunderstood how to execute the code properly.
sean1234
I wrote the below code in a text editor, saved it as foo.rb Now I assume to run it, I simply go into the terminal and enter ruby foo.rb, yet nothing happens.
module Sudoku
class Puzzle
ASCII = ".123456789"
BIN = "\000\001\002\003\004\005\006\007\010\011"
def initialize(lines)
if (lines.respond_to? :join)
s = lines.join
else
s = lines.dup
end
s.gsub!(/\s/, "") # /\s/ is a Regexp that matches any whitespace
raise Invalid, "Grid is the wrong size" unless s.size == 81
if i = s.index(/[^123456789\.]/)
raise Invalid, "Illegal character #{s[i,1]} in puzzle"
end
s.tr!(ASCII, BIN)
@grid = s.unpack('c*')
raise Invalid, "Initial puzzle has duplicates" if has_duplicates?
end
def to_s
(0..8).collect{|r| @grid[r*9,9].pack('c9')}.join("\n").tr(BIN,ASCII)
end
def dup
copy = super
@grid = @grid.dup
copy
end
def [](row, col)
@grid[row*9 + col]
end
def []=(row, col, newvalue)
unless (0..9).include? newvalue
raise Invalid, "illegal cell value"
end
@grid[row*9 + col] = newline
end
BoxOfIndex = [
0,0,0,1,1,1,2,2,2,0,0,0,1,1,1,2,2,2,0,0,0,1,1,1,2,2,2,
3,3,3,4,4,4,5,5,5,3,3,3,4,4,4,5,5,5,3,3,3,4,4,4,5,5,5,
6,6,6,7,7,7,8,8,8,6,6,6,7,7,7,8,8,8,6,6,6,7,7,7,8,8,8
].freeze
def each_unknown
0.upto 8 do |row|
0.upto 8 do |col|
index = row*9+col
next if @grid[index] !=0
box = BoxofIndex[index]
yield row, col, box
end
end
end
def has_duplicates?
0.upto(8) {|row| return true if rowdigits(row).uniq! }
0.upto(8) {|col| return true if coldigits(col).uniq! }
0.upto(8) {|box| return true if boxdigits(box).uniq! }
false
end
AllDigits = [1,2,3,4,5,6,7,8,9].freeze
def possible(row, col, box)
AllDigits - (rowdigits(row) + coldigits(col) + boxdigits(box))
end
private
def rowdigits(row)
@grid[row*9,9] - [0]
end
def coldigits(col)
result = []
col.step(80, 9) {|i|
v = @grid
result << v if (v != 0)
result
end
BoxToIndex = [0, 3, 6, 27, 30, 33, 54, 57, 60].freeze
def boxdigits(b)
i = BoxToIndex
@grid, @grid[i+1], @grid[i+2],
@grid[i+9], @grid[i+10], @grid[i+11],
@grid[i+18], @grid[i+19], @grid[i+20]
] - [0]
end
end
class Invalid < StandardError
end
class Impossible < StandardError
end
def Sudoku.scan(puzzle)
unchanged = false
until unchanged
unchanged = true
rmin,cmin,pmin = nil
min = 10
puzzle.each_unknown do |row, col, box|
case p.size
when 0
raise Impossible
when 1
puzzle[row,col] = p[0]
unchanged = false
else
if unchanged && p.size < min
min = p.size
rmin, cmin, pmin = row, col, p
end
end
end
end
return rmin, cmin, pmin
end
def Sudoku.solve(puzzle)
puzzle = puzzle.dup
r,c,p = scan(puzzle)
return puzzle if r == nil
p.each do |guess|
puzzle[r,c] = guess
begin
return solve(puzzle)
rescue Impossible
next
end
end
raise Impossible
end
end
Technology news on Phys.org
Although you didn't make this clear, that code is from Example 1-1 of "The Ruby Programming Language" by David Flanagan and Yukihiro Matsumoto. Did you try reading the very first comment in the example?
I guess that was a bit unclear for me. It says that it is a "module to solve Sudoku puzzles." I am not really certain what exactly that is.
I was referring to this:
Code:
# Use this module to solve Sudoku puzzles with code like this:
#  require 'sudoku'
#  puts Sudoku.solve(Sudoku::Puzzle.new(ARGF.readlines))
Put that in a new file called "sudoku_solver.rb" or something and run it. You'll need to supply the input filename on the command line.
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
