How to Write Net Ionic Equations for Dissolution Reactions
  • Thread starter Thread starter yellowduck
    Ionic Net
The discussion focuses on writing net ionic equations for dissolution reactions involving NaOH and HCl. For the dissolution of solid NaOH in water, the net ionic equation is NaOH (s) → Na+ (aq) + OH- (aq), while for the reaction between aqueous NaOH and HCl, it simplifies to OH- (aq) + H+ (aq) → H2O (l). When combining the equations, the solid state of NaOH must be retained in the net ionic equation, leading to NaOH (s) + H+ (aq) → Na+ (aq) + H2O (l). Participants clarify that the presence of solid NaOH necessitates writing the complete formula, even in the net ionic equation. The final consensus confirms that the approach to writing these equations is correct, emphasizing the importance of state symbols in reactions.
yellowduck
This should be easy but I feel there is something I am mission
I need to write the net ionic equations and then add #1 & #2 and compare to #3.
Equation #1 - write net ionic equation for dissolution of solid NaOH in water
Equation: NaOH (s) + H2O --> Na+ (aq) + OH- (aq) + H2O (l)
Net: NaOH (s) --> Na+ (aq) + OH- (aq)
(it says in the book to separate strong bases such as NaOH but if I do all ions cancel out?)
Equation #2 - write net ionic equation for aqueous soloutions of NaOH & HCl
Equation: NaOH (aq) + HCl (aq) ---> NaCl (aq) + H2O (l)
Net: OH- (aq) + H+ (aq) --> H2O (l)
Equation 3: Solid NaOH and aqueous HCl
Equation: NaOH (s) + HCl (aq) ---> NaCl (aq) + H2O
OH- (s) + H+ (aq) --> H2O (l)
Add #1 & #2
This is where I get lost. I think it should be net equation #2. The difference is in the solid/aqueous state.
thanks
1. Add #1 to #2.
NaOH \text{(s)} + OH^- \text{(aq)} + H^+ \text{(aq)} \longrightarrow Na^+ \text{(aq)} + OH^- \text{(aq)} + H_2O \text{(l)}
2. Delete the common compounds on both members of the equation.
NaOH \text{(s)} + H^+ \text{(aq)} \longrightarrow Na^+ \text{(aq)} + H_2O \text{(l)}
Is it possible that I have equation #3 wrong.
Should the net ionic equation look like your final answer above?
You have #3 correct, I think.
:approve: :wink:
Solid NaOH in HCl-solution. The HCl-solution contains H^{+} and Cl^{-} but the solid is just NAOH. So the reaction at 3 should be:
NaOH(s) + H^{+} \rightarrow Na^{+} + H_{2}O
So if it states solid, then you must write out the entire formula even in the net ionic equation (because it is infered that the solid is not dissolved in the solution)?
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
