Studiot
- 5,434
- 11
Did you take note of who the original intended audience was?
That too is a very good point.
Studiot said:Comparing this website with the one I linked to in post#21 of this thread I think that 'Ratch' and 'Ratchit' are one and the same person. I note he signs himself Ratch in cabraham's E-Tech thread, although his handle is 'ratchit'.
Studiot said:In June 2008 he started the thread I linked to (post#21) by referring to your site (amasci) as proof that 'transistors are voltage controlled not current controlled'.
Studiot said:I also agree that the weight of practical experience of countless engineers and scientists ove the years have found current control configurations to be the most useful.
wbeaty said:Ooo, here's an idea and a trick question inspired by the transistor war...
What if Ib was actually zero in BJTs?
What if hfe didn't exist? We'd be screwed, right? We could no longer use the linear relation between Ib and Ic. The diode exponential function would become part of everything. To prevent extreme distortion, only very small Vbe signals would be allowed.
Right? :)
cabraham said:If Ib was zero, it would NOT be a bjt!
cabraham said:Any other questions?
wbeaty said:Yes. Still looking for answers:
Do you now understand that my transistor article is not aimed at engineers?
When I stated who the original intended audience was, did you see that message?
cabraham said:Yes, I am well aware of the target audience.
wbeaty said:OK, thanks! And yes, comparing narrow base to extremely wide base is an excellent teaching strategy of which I previously hadn't heard.
Regarding canon, earlier you stated that the Ebers-Moll model is a CC model, and their original paper employed current-controlled current sources. Correct?
Are you certain that you're not misinterpreting something? N.b. that your assertion regarding Ebers-Moll being a CC model goes entirely contrary to numerous undergrad Uni books which give the following CV (large signal transconductance) equation as the central feature of Ebers-Moll model:
Ic=Is*(exp(Vbe/Vt)-1) (for large hfe of course, alpha ~=1)
Is this not canon? If the above CV equation isn't "Ebers-Moll model," then you've discovered a vast flaw in an enormous number of textbooks.
cabraham said:wbeaty said:I'm trying to understand the details of Ebers-Moll.
Based on your semiconductor expertise, would you say that the
Ebers-Moll model depicts the BJT as a current-controlled device?
Yes, that is what figure 5 on page 1765 depicts.
Beware, this could be a case similar to Maxwell's Equations. Go to Maxwell's original work and you won't find his four equations. Maxwell never actually wrote those four, and probably wasn't aware they existed. Maxwell attacked the problem in an obscure way, employing magnetic vector potential, quaternions, and writing twenty equations. Later scientists came in and revised everything, producing the four equations known today. If you rely on Maxwell as the "horse's mouth," then you'd be in big trouble. (Officially the four equations are today called the Hertz/Heaviside equations. But Maxwell discovered the original mathematical form which describes EM fields.)
wbeaty said:I'll take a look.
Beware, this could be a case similar to Maxwell's Equations. Go to Maxwell's original work and you won't find his four equations. Maxwell never actually wrote those four, and probably wasn't aware they existed. Maxwell attacked the problem in an obscure way, employing magnetic vector potential, quaternions, and writing twenty equations. Later scientists came in and revised everything, producing the four equations known today. If you rely on Maxwell as the "horse's mouth," then you'd be in big trouble. (Officially the four equations are today called the Hertz/Heaviside equations. But Maxwell discovered the original mathematical form which describes EM fields.) See 2008 Microwave Journal, 23 years: Acceptance of Maxwell Theory http://bit.ly/qRQNCH
cabraham said:So Bill, is this what you're saying? Your site claims that the CC model of bjt operation is wrong, & you are right.
wbeaty said:I haven't clearly stated my reasoning yet, so do you want to hear it? That's my second question.
cabraham said:Bill, please state exactly what you differ with in the EE canon. Your site makes some pointed criticisms regarding the way bjt operation is presented in engr colleges & semicon OEM app notes.
wbeaty said:I can't answer that without first giving background. My article is aimed at the general public, meaning ~13yr old kids. My goal was to explain simply the inner workings of bjts, and do it without relying on a single equation. Kids have no use for advanced models which cover high frequency operation, high power, etc.
Look, I couldn't explain resistors to the public if I was forced to include the complete high-freq LC model; all we really need is Ohm's law (although even Ohm's law is quite a bit too advanced.) Isn't that obvious? And I certainly wouldn't explain diodes to them using a charge control high-freq model. And Gummel-Poon CC model of the bjt is completely inappropriate for my audience.
That's why I keep asking, did you notice who my audience was? Yes Gummel-Poon obviously is required for VHF design, for accurate spice simulations, etc. But for explaining transistors to people with zero math skills, it's just ridiculous.
Is this clear? CC is wrong. It utterly fails. It's a complete mismatch for the task at hand. It's the wrong tool for the job. (If you're looking for a tool which always works in every situation, well, good luck with that.)So, how would we answer the following question?
What's a good way to explain the inner workings of the BJT to the math-phobic general public?
Above is the whole point of my article.
cabraham said:I agree with that except for the part I highlighted in bold.
I never said this:wbeaty said:Yes Gummel-Poon obviously is required for VHF design, for accurate spice simulations, etc. But for explaining transistors to people with zero math skills, [ Gummel-Poon (CC) ] is just ridiculous. Is this clear? CC is wrong. It utterly fails. It's a complete mismatch for the task at hand. It's the wrong tool for the job.
wbeaty said:CC is wrong. It utterly fails.
cabraham said:So we agree that the discussion is limited to external mAcroscopic modeling, not internal physics.
cabraham said:CC has its limitations, but since we're discussing external models, no internal physics
cabraham said:Bill, you ask "What's a good way to explain the inner workings of the BJT to children?"
My answer is, of course, the 2 diode back to back model.
cabraham said:the Ic value should only be a small value, that associated w/ the c-b jcn reverse leakage current. Namely Ic = -Ics*exp((Vbc/Vt) - 1).
cabraham said:After all, the c-b jcn is reverse biased, so little current can flow. The emitter current Ie is given by Ie = Ies*exp((Vbe/Vt) - 1), of course
So, how can we explain BJTs to children?
wbeaty said:So, how can we explain BJTs to children? To design an explanation, first describe the basic BJT operation verbally:
- Base current controls the BE junction voltage
- BE junction voltage determines height of BE potential-barrier
- That potential-barrier sets the rate of charges crossing the BE junction
- Most carriers from the emitter make it all the way to the collector
- Ic approximately equals Ie
No heresies so far? :)
cabraham said:I believe the problem lies in #3. How does the potential barrier "set the rate of charges crossing the b-e junction"?
wbeaty said:It's a diode.
Is there really a huge controversy about how PN junctions actually work? Is there some thread on physicsforums with a long battle over explaining the diode?
And pay close attention to your question above: how does a potential barrier set the rate of charges crossing [a] junction? If textbooks are fairly unanimous regarding explanation of PN junction potential barrier and resulting currents, then they've answered your question.
cabraham said:Please elaborate. I don't want to be accused of building straw men, but is this what you're saying?
1a) Id = Is*exp((Vd/Vt) - 1), for a diode. Are you claiming what most contrarians claim that Vd "sets" Id?
cabraham said:wbeaty said:OK, then before anything else we need to get clear on some very basic physics... I'm "claiming" the same thing any intro physics text "claims" ...that e-fields cause charges to experience a force... a gravity field applies a force to a point mass, a b-field applies a force to a magnet pole, an e-field applies a force to a point charge.
Do you object?
Of course F = q*E...
