How would I find the volume of the solution?
  • Thread starter Thread starter Valenti
    Volume
The discussion revolves around a homework problem related to calculating the volume of a solution of sodium carbonate hydrate (Na2CO3 nH2O) with a specified molarity of 0.1M and a molar mass denoted as x. Participants explore the steps necessary to approach the problem, including the relationships between moles, mass, and volume.
  • Homework-related
  • One participant expresses uncertainty about the problem due to a lack of clarity in the wording and the absence of a specific variable needed for calculation.
  • Another participant agrees that the wording may be incorrect and suggests it could be a test error.
  • It is proposed that the mass of the hydrate (x) is necessary to calculate the number of moles, which is essential for determining the volume.
  • Participants discuss the need to find the coefficient for H2O by subtracting the molar mass of the anhydrate from the molar mass of the hydrate.
Participants generally agree that the problem lacks clarity and that additional information may be required to solve it. There is no consensus on the exact nature of the missing variable or how to proceed without it.
The discussion highlights potential limitations in the problem statement, including missing assumptions and the need for specific values to perform calculations. The exact molar mass of the hydrate is not provided, which affects the ability to solve the problem.
Valenti
Hey guys had a midterm yesterday but I got stumped on a question with really no idea how to solve it, I'm not really looking for an answer more of a what steps to solve this sort of question. I don't remember exactly what the question was but it was along the lines of Na2CO3 nH2O (This isn't the exact formula just an example since I don't recall what it was) has a molarity concentration of 0.1M find the volume of the solution when the hydrate has a molar mass of x (x was given but I don't remember what it was).
Find the volume of 0.1M of Na2CO3 nH20 with a molar mass of x (x was given in midterm just not sure what it was)
Cm=0.1M
M (Na2CO3 nH20) = x
V= ?
n=m/M
CM= n/v
I figured with the molar mass of the entire hydrate given I would subtract that from the molar mass of the anhydrate then divide that by the molar mass of water, 18, in order to find out the coefficient for H2O. But from here I got stuck as I seemed to be missing another variable in order to calculate either the mass or number of mols in the hydrate.
Doesn't make sense as worded.
Exactly.
Exactly.
Wording may be a bit off since I don't remember what it was exactly, but since these were the only variables given would it be safe to assume it was just a test error?
Assuming you have not missed something - yes, that would be my take.
I think x is the mass of the hydrate and you need to calculate first the number of moles to work out the volume.
  • · Replies 31 ·
