Hydraulic Force: Input & Output of Multiple Pistons
  • Context: Undergrad
  • Thread starter Thread starter wolfy3
    Force Hydraulic
The discussion centers on the principles of hydraulic force and mechanical advantage involving multiple pistons. It establishes that applying 100 lbs of force on a 3" diameter piston results in an output of 33 lbs of force on a 1" diameter piston, with the respective travel distances being 1" and 3". The conversation highlights the necessity of calculating the area of each piston to accurately determine force and travel, emphasizing that the input force and travel remain unchanged when output is distributed across multiple pistons.
  • Understanding of hydraulic systems and mechanical advantage
  • Knowledge of piston area calculations
  • Familiarity with pressure concepts in hydraulics
  • Basic principles of force and motion in fluid mechanics
  • Study hydraulic system design and applications
  • Learn about Pascal's Law and its implications in hydraulics
  • Explore advanced calculations for multiple piston systems
  • Investigate the effects of varying piston diameters on hydraulic performance
Engineers, hydraulic system designers, and students of fluid mechanics seeking to deepen their understanding of hydraulic force distribution and mechanical advantage in multi-piston setups.
wolfy3
Most examples of hydraulic mechanical advantage display a little force on a small piston traveling a long distance to move a bigger piston a short distance with a lot of force.
With the inverse, if we have an input of:
100 lbs of force on a 3" diameter piston traveling 1"
the output would be
33 lbs of force on a 1" diameter piston traveling 3"
and this is true for single pistons.
What happens if the output is forked into 2 or more pistons as my illustration shows?
To have the same travel & force on the small diameter output pistons, would the travel & force on the input piston need to change at all? Or will it stay the same (as with a single output cylinder)?
Thanks in advance.
the output would be
I might be a bit rusty but are you sure about this example?
100lbs on a 3" diameter piston is 14psi
33lbs on a 1" diameter piston is 38psi
You can't use just the diameter of the pistons. You have to calculate the area of each piston.
Piston A = 3 square inches
Piston B = 1 square inch
Applying force to Piston A to move it 1 inch will move Piston B 3 inches, with 1/3rd the output force.
Applying force to Piston B to move it 3 inches will move Piston A 1 inch, with 3 times the output force.
  • · Replies 19 ·
