Hydrostatic pressure and consequences of pascal's law
The discussion revolves around the apparent contradictions in Pascal's law and hydrostatic pressure, particularly how pressure is transmitted in incompressible fluids and the effects of gravity on pressure at different heights within a fluid. Participants explore theoretical implications, practical applications, and the nuances of pressure behavior in fluids.
  • Some participants express confusion about how Pascal's law, which states that pressure applied to an incompressible fluid is transmitted equally at all points, can coexist with the fact that pressure varies with height in a gravitational field.
  • Others argue that while hydrostatic pressure can be considered equal in small-scale scenarios, it becomes significant in larger contexts, such as oceans, where pressure increases with depth due to the weight of the fluid above.
  • A participant suggests that the statement about pressure being transmitted equally should specify that it applies at a given point in the fluid, not universally across all points.
  • Some participants challenge the concept of "net pressure," asserting that pressure is a scalar quantity and does not sum to zero, even if forces acting on a fluid element are balanced.
  • There are examples provided to illustrate how pressure acts in multiple directions at a point, such as in the case of a dam or a submarine hull, emphasizing the multidirectional nature of pressure in fluids.
  • One participant notes that gravitational effects on pressure are stronger closer to the mass attracting the fluid, suggesting that Pascal's law applies under conditions where gravity is negligible.
Participants do not reach a consensus on the interpretation of Pascal's law and hydrostatic pressure. Multiple competing views remain regarding the implications of pressure transmission in fluids and the role of gravity.
Limitations in the discussion include varying interpretations of pressure transmission, the conditions under which Pascal's law applies, and the assumptions regarding gravitational effects on fluid pressure. There is also a lack of resolution regarding the concept of net pressure and its implications in fluid dynamics.
blurrscreen
I've had a doubt about the following (somewhat contradictory) statements.
1) pressure applied to an incompressible fluid is equally transmitted at all points.
2) pressure at points at different heights in a fluid placed in a container in a gravitational field are different.
Gravity applies a pressure on the fluid. If the fluid transmits the pressure equally at all points, then how is pascal's law valid?
For many purposes the hydrostatic pressure is equal everywhere.
But as the scale of the containment increases it must be realized that the weight of the water column increases the pressure ... and more so the further down you go.
This is very significant in the oceans; insignificant in a barrel of water.
You have found an example of physical laws with limitations to their applicability; this happens all the time.
Number (1) is stated incorrectly. It should read "pressure within an incompressible fluid acts equally in all directions at a given point in the fluid." This is Pascal's law observation.
Chet
If it acts equally in all directions at a given point, then why isn't the net pressure at all points in a fluid zero?
It's at a given point not at all points.
I think 1) is a reasonable restatement of Pascal's Law.
For 2) you are essentially summing up all the pressures from the weight of the fluid. So as you work your way down the effect is cumulative.
I don't see a contradiction between the two, rather 2) follows as a consequence of 1).
Alright, consider one point at a certain depth in a fluid. If the pressure along all directions is equal, then the net pressure there is zero. So why do fluids have pressure at all?
Paisiello, thanks for the response. But imagine gravity pushing down on the fluid, thus applying a pressure to it which, according to pascal's law is equally transmitted at all points. Then why do points at different heights in the fluid have different pressures.
If you take a tiny cube of fluid at a given location in the fluid as a free body and the fluid is static, then the pressure on each of the 6 sides of the cube is p. The cube is in static equilibrium, and the net force on the cube is zero, but that doesn't mean that the force on each of its sides is equal to zero.
Chet
True, but the NET pressure at every point is zero. Then why does fluid pressure exist?
If you have a solid cube (e.g., not submerged in liquid), and you apply equal normal forces on all six of its sides so that the NET force on the cube is zero, are you asking why force exists?
Chet
Pressure is a scalar so it doesn't sum to zero, but even if it did, summing to zero doesn't mean the force is zero, it just means there is no motion. If you put your hand in a vise and crank it down, the forces sum to zero too - but it still hurts!
In all directions, not at all points.
Do you feel more pressure sitting on top of a pile of bricks or under it.
There is no such thing as "net pressure". Pressure is a scalar, not a vector.
I always thought that pressure is defined as force per unit area; thus pressure can have a direction.
See http://hyperphysics.phy-astr.gsu.edu/hbase/press.html
This is usually most important at the boundaries - for example, inside the bubble the pressure is pointing outwards at the surface, and the air pressure is pointing inwards.
For ball under water the external pressure is all pointing inwards - until the ball (or submarine) is crushed.
Here is another example to illustrate item (1). Suppose you have a dam. At any given depth (location) right next to the dam, the water pressure is not only acting up and down. It is also pressing sideways (horizontally) on the face of the dam. This is all that item (1) is saying.
Another example is a submarine hull. The water pressure doesn't only press down on the top of the hull and up on the bottom of the hull. It also presses sideways on the sides of the hull.
The same happens to you when you go down to the bottom of a swimming pool at the deep end. If you are standing on the bottom at the deep end (say, held down by weights), the water presses horizontally on your sides as well as on the top of your head, even though your sides are nearly vertical.
Chet
Actually, if we are getting technical, pressure is the isotropic part of the (second order) stress tensor. Under hydrostatic conditions, the stress tensor is equal to p times the identity tensor. To get the force per unit area acting on a surface, one simply dots (contracts) the stress tensor with a unit normal vector to the surface. This yields the pressure times the unit normal. So the pressure always acts normal to surfaces, as UltrafastPED has indicated.
Chet
Gravity does not apply pressure equally it's stronger the nearer you are to the body that's attracting. Pascal's law allows pressure to be to be equally transmitted when gravity is ignored or pressure is applied in it's absence.
Variation of gravitiational attraction with distance between the attracting bodies is typically not a significant contributor to hydrostatic pressure variations in practice (on the scale of a swimming pool or a glass of water, or even the depth of the ocean). The main contributor is the weight of the overlying fluid. Irrespective of this, I stand by what I said. The pressure at any given location is pushing equally in all directions. This applies whether the pressure is the result of a hydrostatic column of liquid, or whether the liquid is in a cylinder being squeezed by a piston. In fact, it applies not only to incompressible liquids but also to compressible gases.
Chet
Chet
What causes the variation in the pressure of the overlying fluid.
Why is there more pressure at the bottom of a column of water than the top.I agree that at any given location or point the pressure is equall but if you measured the pressure at a piont at the bottom of a column of water and then at another point at the top won't the two locations be pushing with different amounts of force when compared.
Suppose you have a cylindrical tank full of water. The pressure at the top surface of the tank is just atmospheric pressure. The pressure at the bottom of the tank is atmospheric pressure plus the weight of the water in the tank divided by the area of the base A. The weight of the water in the tank is equal to the mass of water in the tank times g. The mass of water in the tank is equal to the density of water ρ times the volume of water in the tank. The volume of water in the tank is equal to the area A of the base times the depth of the water h. So,
Pbottom=Patmospheric+ (ρAh)g/A =Patmospheric+ ρgh
Sure. But that's not what item (1) is saying. Item (1) is saying that, at any point near the top of the tank, the pressure is the same in all directions and, at any point near the bottom of the tank, the pressure is the same in all directions.
Chet
The answer to this is that gravity does not apply pressure, it is a force with a very different nature than pressure. Gravity is what is known as a "body force", which means, if you think in terms of time rate of change of momentum, gravity acts to remove momentum from every gram of material at a fixed rate. Since it in some sense "acts on the body of the system", since it removes momentum per gram, it is a body force. What this means is, you should think of it as source or sink of momentum that does not need to move any momentum through any boundaries, it just plain deposits or removes it (depending on the sign you are imagining) at every point in the body, like magic if you will.
Pressure is quite different, because it is a surface force. The key difference is that when you think about how pressure adds or removes momentum from something, it always has to pass that momentum through the surface of that something, it cannot just make momentum appear like magic the way gravity does.
In the problem you are thinking about, like water in a pool, all the surfaces we need to think about are horizontal surfaces, and the only direction we need to worry about is vertical. This simplifies the situation, we don't need to worry about the fact that pressure is isotropic, we can just look at what it is doing with momentum in the up and down directions, and that suffices to see what is going on in a pool.
So imagine any horizontal surface inside the water in a pool, and ask, what kind of momentum is passing through that surface? The answer is, pressure is causing upward momentum to pass upward through that surface, and an equal amount of downward momentum to pass downward (that's the "isotropic" aspect). Let's call this equal rate of momentum crossing the surface in either direction P1A/2 (the notation is motivated by the fact that P is pressure and A is area, but it doesn't matter, it's just a number I'm talking about). It doesn't matter how it is doing that, this is just what pressure does, but if you want to know how, realize it is the action of all the little water molecules that are moving up and down across that surface all the time-- an upward molecule is obviously going to transport upward momentum upward across the surface, and a downward molecule is going to transport downward momentum downward across the surface. Now your question is, if an equal amount of upward momentum is moving upward as downward momentum is moving downward, why does anyone care?
Good question, and it has a good answer. Next imagine a second surface that is a bit deeper down below that first one. Again the same amount of upward momentum is crossing upward as downward momentum that is crossing downward, but the numerical value of this rate of crossing of momentum is different from before, now call it P2A/2, and you will not be surprised to hear that P1 < P2, since I mentioned that P is really pressure here.
Now for the reason you care about these P: think about an imaginary box that is bounded above by the first surface, and below by the second surface, and think about the rate that momentum is entering this box. There are 4 terms you have to add up, two from the top surface and two from the bottom. The top surface has P1A/2 rate of downward momentum coming down into it, so that's a net accumulation of downward momentum. It has the same rate of upward momentum leaving it upward, but here's the reason they don't cancel-- upward momentum has the opposite sign from downward momentum! So having upward momentum leave has the same effect as having downward momentum enter. Thus the two terms add up to a total of P1A, not to zero. In short, there is downward momentum entering the imaginary box through its upper surface, which is a downward force on the box, due to the P at its upper boundary.
Play the same game at the lower boundary, and you will find that P2A is the rate that upward momentum is entering from below, but that's the same as -P2A rate of downward momentum, since momentum is a vector. So the top and bottom momentum fluxes are the things that might cancel out, not the momentum passing through a given surface into our imaginary box. But if there's gravity, that body force that is adding downward momentum to the mass in the interior of our box, then we can only get force balance if pressure is removing downward momentum (or adding upward momentum, it's the same thing), and that's what the surface momentum fluxes that pressure controls is doing. That's why P1A < P2A, and that's why pressure matters, even though it is locally isotropic. It matters because it is different in different places, and Pascal's law says that once you have set up those differences, if you exert additional pressure (like adding weight to the top, for example), it can't affect the differences in pressure, because those were already what they needed to be to move a net flux of momentum around as needed to balance gravity.
Thanks for all the help! Hydrostatics was a little tough for me to grasp.
New doubt!
Consider a point at a certain depth in an ideal fluid. We say that pressure at that point is due to the weight of the fluid above it. But since the fluid is static, the fluid layer at that depth must exert some sort of reaction force to the weight of the fluid. Why don't we consider this when we calculate pressure at a given point in a fluid.
All forces come in pairs, so you'd be counting the same force twice. For example, if you squeeze your thumb and finger together with 10N force, that requires one finger pushing one way at 10N and the other pushing in the opposite direction with the same force.
We do, that's what pressure is. Many people think pressure is a force per unit area, but not always-- it only becomes a force when you strip away half the stuff, leaving the force from the other way unbalanced. But pressure usually isn't like that, it's only like that at a boundary and only if you look at only have the story. So you can think of pressure two different ways-- either say pressure is a force per unit area, and only exists at a boundary, so when you talk about it in the interior, you imply you have stripped away one side and created a boundary. That's what we mean when we say "a piston exerts a pressure", so it's best used for external pressure. Or, we can say that pressure is a momentum flux per unit area, coming from both sides, so exists in the interior of the fluid or solid, and is best thought of as an interior pressure. Your confusion is between these two rather different, yet quantitatively equal, meanings of pressure.
Exactly, but anything kept in the middle(in this case the point in the fluid) must experience both forces. The pressure hence must be twice what we experience. Why isn't it so?
Excellent question. Consider a crowd of people hitting tennis balls against a wall, and bouncing back. Now consider a similar crowd on the other side of the wall, doing the same thing. There is no net force on the wall, by symmetry, but there is "pressure", and you can get that pressure by looking at the rate the tennis balls are "depositing momentum" into the wall from either side (not both, there is no net deposition from both as there is no net force). Now remove the wall-- what changes? Nothing! The balls look exactly the same on average. There is still no net force in the middle plane, just as there was not before, and there is still pressure there, just as there was before! You don't even need the balls to collide with each other, pressure has no direct requirement for collisions.
Now your question is, but wait a minute, when you have the wall, we are only counting the pressure from half the balls, and when we remove the wall, we are counting all the balls. Do we not make a factor of 2 error? No, we do not, because when there is a wall, the balls from one side are bouncing, so they deposit their momentum twice. When there is no wall, the walls do not bounce, but there are twice as many that participate in the counting. This is that "two different ways" to think about pressure, that give the same answer.
Alright. So when we measure pressure without an object at that level, we must consider both forces, right?
It does experience both forces, but the situation hasn't changed any: now you have four forces instead of two, all of which are balanced and equal to 10N.
Instead of 10=10, you have 10=10=10=10.
In order for forces to be additive, they have to be applied at the same point and pointed in the same direction. Here, the forces are opposite each other.
  • · Replies 22 ·
9K
  • · Replies 48 ·
