Hypothesis Test for Balanced Load on 6 I/O Channels - N = 150
  • Thread starter Thread starter TomJerry
    Test
The discussion centers on testing the hypothesis that the load on six I/O channels is balanced, given that the observed operations on each channel are uneven. The chi-square test is suggested as the appropriate method, with the formula χ² = (O-E)²/E, where O represents observed values and E represents expected values. The expected load for each channel is calculated as E = 150/6, resulting in an expected value of 25 operations per channel. Participants confirm that this approach is correct for testing the hypothesis at a 5 percent significance level. The conversation highlights the importance of correctly applying statistical methods to validate assumptions about system performance.
TomJerry
Question : A computer system has 6 I/O channels and the system personnel are reasonably certain that the load on channels is balanced. If X is random variable denoting the index of the channel to which a given I/O operations is directed , that its pmf is assumed to be uniformly distributed. Out of N=150 I/O operation onserved, the number of operations directed to various channels were:
n0 = 22 ; n1 = 23 ; n2 = 29 ; n3 = 31 ; n4 = 26 ; n5 = 19
Test the hypothesis that the load on channels is balanced at 5 percent level of significance.
Solution
I have used the \chi2 = (O-E)2 / E
where O - obsevred and E is expected
Is this correct or should i be using some other method
TomJerry said:
Question :
You can use the chi square test \chi^2=\sum (O-E)^2/E Do you know how to get E?
I have taken all the E = \Sigmaxi/6
Is that correct?
Is that correct?
Yes. If each I/O is taken as equally probable, 150/6=25=E.
Thanks
If you're being sarcastic, why did you ask for confirmation in the first place?
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
