I am new to Calculus. rate of change
Abu Rehan
I am new to Calculus. I know that the rate of change in some thing is called it's derivative or we differentiate something to find the rate of change in it. But while differentiating or better to say proving that if f(x)= sinx then f'(x)= cosx, we take f'(x)= lim h->0 [sin(x+h)- sinx]/h. Can you explain why?
I know formulas like sin2x+ cos2x= 1
And the rest used in proving this.
Mathematics news on Phys.org
Well to find the derivative of f(x) you find the the slope of the tangent line at every point x. To do this imagine a secant line intersecting the function at 2 points, (x,f(x)), and (x+h, f(x+h)). Finding the slope of the secant line, which is [f(x+h) - f(x)]/h, will approximately give you how the function is changing, depending on how small your "h" is. To find the tangent line, which only intersects the function at point (x, f(x)), simply let "h" go to zero. That gives you your formula for differentiation.
Do you mean you want to know why, if f(x) = sinx,
f'(x) = \lim_{h\rightarrow 0} \frac{\sin(x + h) - \sin(x)}{h} = \cos x ?
You would first start by expanding sin(x + h) using the sum formula for sine, rewrite things a bit, then use some trig limits to evaluate the limit for the derivative.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
