Fortran I to solve ODE with rk4 y" + 2y =0 in fortran
  • Thread starter Thread starter mlouky
    Fortran Ode Rk4
The discussion centers around solving the ordinary differential equation (ODE) y'' + 2y = 0 using the Runge-Kutta 4th order (RK4) method in Fortran. The original poster seeks assistance in implementing this numerical method, initially stating a boundary condition of y(0) = 0 and y(1) = 1, while also mentioning y(x) = cos(2x) as a potential solution. However, it is clarified that y(x) = cos(2x) does not satisfy the ODE. Further clarification reveals the poster's intent to solve y''(x) = -2cos(2x) with initial conditions y(0) = 1 and y'(0) = 0. The discussion emphasizes that RK4 should be applied to the ODE in its standard form, with the correct initial conditions specified. The importance of not leveraging the analytical solution of the ODE while implementing the numerical method is also highlighted.
mlouky
How can i solve y" + 2y =0 with RK4 and their program fortran
please I néed your helpe
Technology news on Phys.org
my ey is y"+2y weith y(x) = cos(2x)
voila mon progam
Program second_ordr
implicit none
integer, parameter :: n=21 ! number of base points
double precision, external :: f
double precision, dimension(1:n) :: x, y, dy ! x, y, y'
integer i
open (unit=22,file="result.dat")
! boundary values
x(1) = 0.0
y(1) = 0.0
x(n) = 1.0
y(n) = 1.0
! assumptions for y'(1) - use dy(1) and dy(2) here only as a storage
dy(1) = 1
dy(2) = 0
write(*,100)
do i=1,n
write (*,101) x(i), y(i), dy(i)
end do
100 format(5x, 'x',11x, 'y',11x, 'dy')
101 format(3(1pe12.4))
stop
end program second_ordr
function f(x,y,dy)
implicit none
double precision f, x, y, dy
f = 0.55*cos(0.55*x)
end function f
subroutine rk4_2d(f,x,y,dy,n)
implicit none
double precision f
integer n
integer i
double precision h,k11,k12,k21,k22,k31,k32,k41,k42
do i=2,n
h = x(i)-x(i-1)
k11 = h*dy(i-1)
k12 = h*f(x(i-1),y(i-1),dy(i-1))
k21 = h*(dy(i-1)+k12/2.0)
k22 = h*f(x(i-1)+h/2.0, y(i-1)+k11/2.0, dy(i-1)+k12/2.0)
k31 = h*(dy(i-1)+k22/2.0)
k32 = h*f(x(i-1)+h/2.0, y(i-1)+k21/2.0, dy(i-1)+k22/2.0)
k41 = h*(dy(i-1)+k32)
k42 = h*f(x(i-1)+h,y(i-1)+k31,dy(i-1)+k32)
y(i) = y(i-1) + (k11 + 2.0*(k21+k31) + k41)/6.0
dy(i) = dy(i-1)+ (k12 + 2.0*(k22+k32) + k42)/6.0
end do
end subroutine rk4_2d
y(x) = cos(2x) is not a solution of y'' + 2y = 0.
mlouky said:
voila mon progam
Mod note: Added [ code ] and [ /code ] tags, below.
Fortran:
Program second_ordr
implicit none
integer i
! boundary values
x(1) =  0.0
y(1) =  0.0
x(n) =  1.0
y(n) =  1.0
dy(1) =  1
dy(2) =  0
write(*,100)
do i=1,n
end do
stop
function f(x,y,dy)
implicit none
  end function f
implicit none
double precision f
integer n
integer i
do i=2,n
  h  = x(i)-x(i-1)
  k11 = h*dy(i-1)
end do
Note - you're not suppose to take advantage of the fact that the ODE can be solved, y = c1 sin(sqrt(2) t) + c2 cos(sqrt(2) t).
RK4 is supposed to used with an ODE. Instead of using y and x, it may help to use y for position and t for time. y(t) is a position, y'(t) is a velocity, and y"(t) is an acceleration. For RK4, the ODE should be written as y" = -2y. The initial condition is y(0) = 0, y'(0) = 1, and y"(0) = 0. For a given y"(t), y'(t), y(t), RK4 calculates y'(t+Δt), y(t+Δt), and then y"(t+Δt) = -2 y(t+Δt), t = t+Δt, and the process continues for each time step Δt.
Marrk44
I explain exactly what I want
I have an ordinary differential equation of order two y "(x) = -2cos (2x)
I am looking to solve numerically the RK4 method to write a program in FORTRAN
with y (0) = 1 and y '(0) = 0
thank you very much
thanks rcgldr
thank you very much
That is not what you wrote in your opening post. There you wrote that you want to solve $y'' + 2y = 0$, but you did not specify initial conditions. In your second post you wrote that you want to solve $y'' + 2y = 0$ with $y(x) = cos(2x)$ and boundary conditions $y(0)=0, y(1)=1$. As Mark noted, $y(x) = cos(2x)$ is not a solution of $y'' + 2y = 0$.
So which is it?
If you truly are to numerically solve $y''+2y=0, y(0)=1, y'(0)=0$ using RK4, you should not be taking advantage of the fact that $y=\cos(\sqrt(2)x)$ is the solution.
ok I understand thank you
