I want to Ionize Hydrogen in a Balloon
  • Thread starter Thread starter Jedi_Sawyer
    Balloon Hydrogen
Ionizing hydrogen in a balloon using a 20KV source is ineffective due to insufficient electric field strength relative to the pressure of the hydrogen. Covering the balloon with tin foil and applying the voltage did not yield results. Concerns are raised about the dangers of hydrogen explosions if a leak occurs, especially with high voltage present. Despite the risks, some participants suggest they have ideas for achieving ionization. The discussion highlights both the technical challenges and safety hazards involved in this experiment.
Jedi_Sawyer
Right now I blow up latex balloons with hydrogen. I am using the 20KV from a TV anode. I don't seem to be able to just stick the bare wire end of this HV source to ionize the Hydrogen. Covering the outside of the balloon with tin foil and putting the 20KV on that did next to nothing.
Any ideas how I can ionize the hydrogen inside the balloon?
You like to play dangerous games, don't you !
The answer why it doesn't work is that the pressure of the hydrogen is too high, and the electric field too low: you have 20 KV over several cm at 1 bar, this is simply not strong enough.
But I would urge you to stop doing what you do: if ever you have a leak, and you have a spark because of the HV, then you will have a rather powerful hydrogen explosion.
No I am just using just a little hydrogen in about 10" Balloons, even if ignited it would just flash about like a fire cracker, but even a 20KV arc that popped the balloon didn't catch it on fire.
So nobody knows
So nobody knows how to do this, well I have some ideas
Since you already know, then this thread is moot.
Zz.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
