I want to move an object on the screen a fixed distance in a fixed tim
  • Context: Undergrad
  • Thread starter Thread starter cubud
    Screen
This discussion focuses on calculating the initial velocity and acceleration required to move an object a fixed distance with a smooth stop. The user aims to move an object 64 meters in 2 seconds, starting from rest, accelerating for half the distance, and then decelerating. The relevant equations used include s = ut + 0.5at², which simplifies to a = 2s/t² for the acceleration phase. The final calculations yield an initial velocity of 6.5 pixels/second for a distance of 21 pixels over 6 seconds with a deceleration of -1 pixels/second².
  • Understanding of basic physics concepts, specifically kinematics.
  • Familiarity with the equations of motion, particularly s = ut + 0.5at².
  • Knowledge of programming concepts to implement motion calculations.
  • Experience with easing functions in animation or game development.
  • Research "Kinematic equations for motion" to deepen understanding of object movement.
  • Learn about "Easing functions in animations" to apply smooth transitions in graphics.
  • Explore "Physics engines in game development" for more complex motion simulations.
  • Investigate "Implementing motion in programming languages" relevant to your projects.
Programmers, game developers, and anyone interested in implementing smooth motion and easing effects in animations or simulations.
cubud
Hi everyone.
I am a programmer and I think some basic physics will help me to achieve something I wanted to do.
I want to move an object on the screen a fixed distance in a fixed time, but rather than moving with a uniformed velocity I want it to slow down at a constant rate so that it runs to a smooth stop.
So if for example I wanted to move 64m over 2s, how would I work out what my initial velocity and acceleration should be?
I appreciate any help. In fact I don't actually need to do this any more, but because I didn't know how to achieve the requirement I now have a strong urge to know how it should be solved.
So you want it to start from rest (u=0) accelerate for a while then decelerate to a stop 64m away from the start in time (T=2 seconds).
Ok let's assume the rate of acceleration and deceleration are the same. In that case the problem can be split in two parts.
1) Acceleration phase...
It has to cover the first 32m in 1s. The relevant equation would be
s = ut + 0.5 at2
where
s = the displacement
u = initial velocity = 0
a = acceleration
t = time
Since u=0 it simplifies to
s= 0.5 at2
or
a = 2s/t2
= 2*32/12
= 64m/s2
2) The deceleration phase is identical except "a" will need to be negative.
Let me see if I can clarify. At an acceleration rate of 1pixel/second^2 I would expect my object to have the following Y locations over 6 seconds.
0,1,3,6,10,15,21
What I need to do is the opposite. I wanted to understand an equation that when given the acceleration rate (-1 pixels/s^2), distance to travel (21pixels), and the total time over which to travel (6s) I end up with the initial velocity - resulting in the following
Distance = 21pixels
Time = 6 seconds
Acceleration -1pixels/second^2
= Initial velocity of 6 pixels/second
Which would give me the following positions.
21,15,10,6,3,1,0
In which case you need...
s = ut + 0.5 at2
rearranged to give u the initial velocity..
ut= s - 0.5at2
u = s/t - 0.5at
Edit:
gives u = 6.5 pixels/second
I will give this a try, thank you!
Worked great, I thought I'd share the source in case anyone else stumbles across this. It should be pretty easy to work out the calculations from it.
Code:
function TSpriteBehaviorMoveTo.GetFullyEasedOffset(
  Original: Single;
  Target: Single;
  DurationSecs: Single;
  TotalDeltaTime: Single
): Single;
var
  HalfDistance: Single;
  HalfTime: Single;
  Acceleration: Single;
  CurrentTime: Single;
begin
  HalfTime := DurationSecs / 2;
  HalfDistance := (Target - Original) / 2;
  Acceleration := HalfDistance / ((HalfTime * HalfTime) * 0.5);
  if (TotalDeltaTime <= HalfTime) then
  begin
    CurrentTime:= TotalDeltaTime;
    Result := Original + (0.5 * acceleration * CurrentTime * CurrentTime);
  end else
  begin
    CurrentTime:= DurationSecs - TotalDeltaTime;
    Result := Target - (0.5 * acceleration * CurrentTime * CurrentTime);
  end;
end;
  • · Replies 16 ·
  • · Replies 39 ·
  • · Replies 16 ·
  • · Replies 17 ·
