Identifying & Accounting for Systematic Error in Scales with 1mg Capacity
  • Context: Undergrad
  • Thread starter Thread starter Jhon81
    Error Systematic
The discussion revolves around identifying and accounting for systematic errors in scales with a capacity of 1mg. Participants explore various methods for detecting and correcting these errors, particularly in the context of weighing very small amounts of material.
  • One participant suggests using tare weight to account for systematic error, indicating that the tare includes both the container's weight and any fixed error in the scale.
  • Another participant proposes using calibrated weights of known masses as an alternative method to identify systematic errors.
  • A participant expresses concern about weighing small amounts of powder directly on the scale, recommending the use of a thin piece of paper to avoid damaging the scale.
  • One participant mentions the concept of "Gage R&R" as relevant to understanding systematic variations in measurement and provides links for further reading.
  • Another participant discusses the calibration of the scale using a 100g weight, questioning whether the observed discrepancies in weight readings could indicate a systematic error and whether it can be corrected.
  • It is noted that calibrating at 100g may not be optimal for weighing less than 1g, suggesting that calibration should also include lower weights like 1g and 10g.
Participants present multiple competing views on how to identify and account for systematic errors, and the discussion remains unresolved regarding the best approach to calibration and error correction.
Participants express uncertainty about the effectiveness of different calibration weights and methods, and there are limitations regarding the assumptions made about the scale's performance at varying weights.
Jhon81
Hi everyone,
I have a scale that should weight as low as 1mg, if there was a systematic error how could I identify it and include it in my calculations?
I assume you are accounting for Tare.
Put the container on the scale and weigh it. That's your tare.
Then put the material you want to weigh into that container and place the container back onto the scale and weigh it. Then subtract the tare.
That tare will include the weight of the container and any fixed error in the scale.
If that is the type of systematic error you are talking about, then you have your answer.
Otherwise, explain it more detail.
Besides the approach mentioned above, the other approach is to use a set of calibrated weights of precisely known masses.
Then put the material you want to weigh into that container and place the container back onto the scale and weigh it. Ten subtract the tare.
Hi Scott,
I am going to weight a very small amount of powder ( 0.7 gm ), so I do not think that using a container will help for this small amounts.
Hi Dale,
I was thinking of calibrating the scale every time I use it to minimize the error.
I have a 100 gm weight to calibrate the scale so after calibration I weight it and gave me ( 100.320gm, 100.460gm, 100.630gm), can this be a systematic error and can i correct it?
Jhon81 said:
Hi Scott,
If you are using a good scale, do not put the powder directly onto it. That's not a good way to measure and it's not a good way to treat you scale.
Use something like a thin piece of paper. Measure the paper first, then put the powder on the paper and weight them together.
Also, if you are serious about knowing you systematic variations in measurement, the topic you are interested in is called "Gage R&R".
I will look for a good link - but here are a couple until I find a good one:
https://www.managementstudyguide.com/causes-of-measurement-variation.htm
https://en.wikipedia.org/wiki/ANOVA_gauge_R&R
edit---
OK: Here is a better link:
https://support.minitab.com/en-us/m...s/gage-r-r-analyses/what-is-a-gage-r-r-study/
When you go to that link, note that there are a list of related topic listed on the left. For example, check out "Worksheet Randomization for a Gage R&R Study".
Jhon81 said:
Hi Dale,
If you are trying to weigh less than 1 g then calibrating at 100 g will be suboptimal. You will be much better off calibrating to 1 g and maybe 10 g too. Be sure to check your calibration weight’s manufacturer specifications to know the tolerance and any proper handling/cleaning.
  • · Replies 21 ·
  • · Replies 27 ·
12K
11K
  • · Replies 25 ·
  • · Replies 28 ·
  • · Replies 72 ·
  • · Replies 21 ·
