Identifying three identical metal bars (with your eyes closed )
To identify three identical metal bars consisting of a permanent magnet, soft iron, and copper while blindfolded, one can easily recognize the copper bar as it will not be attracted to the others. Distinguishing between the permanent magnet and soft iron can be achieved by leveraging their magnetic properties; the permanent magnet will attract the soft iron, while the soft iron will not exhibit attraction to the magnet itself. A practical method involves testing the ability of one bar to pick up the other, as the magnet will be able to lift the soft iron, whereas the reverse will not occur. The discussion highlights the limitations of using eddy currents for this identification, suggesting that a more straightforward approach is preferable. Ultimately, the interaction between the bars provides a clear means of identification.
IRNB
Identifying three identical metal bars (with your eyes closed!)
How would you determine, non-destructively, and with eyes closed, which is which amongst three identically-shaped metal bars known to consist of a permanent magnet, a piece of soft iron and a piece of copper?
N/A
I know you could identify which is the copper bar because it wouldn't be attracted to either of the other two bars but I am not sure how to determine which bar has the permanent magnet and which has the soft iron.
Could you perhaps use the effect of eddy currents to determine which is the parmanent magnet and which is the bar with the piece of soft iron. What I'm thinking is, trying to move the copper bar in the presence of the parmenant magnet should be more difficult then moving it in the presence of the soft iron bar.
Well, you beat me to it! Outstanding work!
I don't think the eddy currents would be strong enough to realistically tell the difference, but theoretically, it should work.
There is a more realistic method of determining which is the soft iron and which is the magnet. It is something that anyone can do and see. IT has to do with one picking up the other. Putting the bars end to end wouldn't make the distinction, but what's an alternative way of one picking up the other?
