Identifying Winding Pairs
  • Thread starter Thread starter Grubbs1960
66 replies · 7K views · last reply
In this case DC current and a magnetic compass are not needed, because the connections of these Dahlander motors is internal, so relative polarity of the coils cannot be reversed. When you look at a row or a column in the resistance table, the two lowest resistance wires identify the ends of the two closest coils. So for example, #7 is between #8 and #16. That process continues to fully identify the ring of six coils.
Since the two rings of six coils show no connection, we know that there could be at most, one wire shorted to the motor frame. You should check the insulation is good, from the motor frame to one wire on each of the two windings. Remember to protect the coil insulation, by earthing the motor frame.
The experiment comes when you connect power to the motor. You need a fast breaker in case there is something unexpected. Three filament lamps rated to the line voltage will limit fault currents if there is a problem. Equal lamp dimness will tell you if things are balanced. Then you can apply the full supply, without the lamps.
Guineafowl said:
If it’s any help, it looks like your two Dahlanders are:
1. 3600-1800 switching 2 to 4-pole
2. 1200-600 switching 6 to 12-pole.
I’ve also seen someone using a DC power supply to inject controlled current into winding ends, watching the behaviour of a compass needle to check the phasing is correct.
OK, that is almost what I just figured out.
But it is 3, 6, 12, and 24 pole. Being used to thinking about single phase motors, which need an even number of poles, but not for 3-phase.
So, the 12 and 24 pole version will use all pairs of consecutive poles.
And the 3 and 6 use groups of 8 poles. I was trying to figure out before why 16 and 8 are not divisible by 3, (or 6), but it works if you do it that way.
The effect is of 24, 12, 6, or 3 poles, and 600, 1200, 1800, and 3600 RPM.
If you follow the previous suggestion of a small DC current, and a compass, you should be able to figure out the pole polarity, with different windings.
I’m not sure what you’re driving at there ^. Are you trying to equate the number of stator slots with pole number?
For three phase motors, the number of poles is given per phase, so a 2-pole version will have 6 poles overall. For the synchronous speed, you use the per phase (P) figure in this equation:
$$N_s = \frac {120f} {P}$$
Hence, the field of a 2-pole (per phase) 60 Hz three phase motor will spin at 3600 rpm.
As far as I know, there are no 3-pole induction motors. It has to be an even number.
I’ve just re-read the thread. Sorry, Baluncore, I missed that you’d already mentioned the compass trick. I take your point about this not being useful when each of the 6 windings aren’t separate.
Each set of 6 wires comes from a series delta, and each wire is from two winding ends either at a vertex or a mid-point. The vertices are the ones commoned in the double-star mode.
- Can we assume that the lowest-numbered wire is a vertex, and that increasing numbers count round the delta in a direction that’s consistent between the two Dahlanders?
- if we muddle the vertices with mid-points, does it matter?
- For the OP, does the lathe have a reversing switch before the speed selector? This would be a useful feature for threadcutting.
I wired the lathe today and it seems to be running as expected, although I have not yet attempted any actual turning.
No reversing switch. This is a wood lathe, so there is little likelihood of threadcutting.
The four-speed motor is quite an impressive feature, given the more common pulley arrangement for speed changes. There’s a short article on Oliver’s UK arm (and another on their US metal lathes in the main archives) on this excellent site: https://www.lathes.co.uk/oliveruk/
They’re always looking for pictures and details of machines.
Thanks for that link. We have a couple of similar websites here in the USA: https://www.owwm.org/ and vintagemachinery.org.
I have done some additional testing of the motor and observed some things that are puzzling/concerning:
1. When wired in the 600 rpm configuration, the VFD limits the speed to ~300 rpm because the motor is drawing max amperage (2.3amps). This is with no load.
2. When wired in the 1800 rpm configuration, it will run at the full 1800 rpm, but is drawing max amperage with no load.
The motor turns freely when rotated by hand.
I should add that since my motor tag doesn’t specify FLA, I have set that parameter on the VFD to 2.3 amps, the default for a 1/2hp motor.
I talked with tech support at the VFD manufacturer. They had me auto tune the drive and then see what winding resistance the drive detected. It was 8.9 ohms, which matches what I measured via ohmmeter. The drive tech support said that the expected resistance should be around 5.6 ohms.
Resistance across the 600 rpm windings measured 12.0 ohms with my ohmmeter, so that probably explains why the rpms were limited to 1/2 the rated speed in that configuration.
What I would like to understand is whether these higher than expected resistance values are because:
a. those are to be expected for a Dahlander winding configuration.
b. back when these motors were built they “overbuilt” or couldn’t achieve the efficiency of modern motors.
c. there is something faulty or incorrect with this motor’s windings.
In the case of a or b, might it be feasible to run the motor using a higher hp rated VFD? When I mentioned that I had a 2 hp VFD, the tech suggested that I connect it to the motor and monitor the amperage to see what kind of draw occurs with the motor under load. It will be quite some time before I can do this as I have some additional refurbishing to do on tool rest and tailstock before I actually put the lathe into service. And it is likely that before I can get that accomplished I will be traveling for a couple of weeks. But I thought I’d throw this out there in case someone had some helpful advice.
Re: windings, I’d be checking the insulation resistance, if you have access to a megger. Sanity check - does the VFD output voltage match the motor?
It’s normally one VFD per motor, and you technically have four. The Dahlander on my 1950s spindle moulder (wood shaper) acts as two motors, being 3hp in low speed and 4hp in high. There’s also not supposed to be any switchgear between the VFD and motor. That’s why Dahlanders are tricky to run, and somewhat redundant, with VFDs.
- Pick a medium speed configuration, and control the lathe’s speed with the VFD? You can then tune and fettle the VFD’s overload settings. Try bumping the overload setting 10% and trying some turning. There’s nothing wrong with using a bigger VFD than the motor - I’ve been doing this for years with a 1.5 kW unit running a 500W motor.
- I know of someone who uses a VFD with a small idler motor permanently connected, to make a more versatile phase converter which copes with switchgear. I can ask him for details if you like.
One thing I’ve not seen before is the speed/frequency limiting you describe with the 600 rpm configuration. Is there something about this in the manual?
I do not have access to a megger. But I would like to understand this better. My perhaps incorrect/incomplete understanding is that a megger induces a high enough voltage to the windings that if there was a small fault in the winding insulation, it could be detected even though a regular ohmeter would not be able to detect said fault. But if that were the case with my motor, why would that create high resistance in my windings? Seems it would be the opposite.
My motor is rated 230v, and that is what the voltage output parameter on the VFD is set at.
Well, this is one reason that I removed the switchgear and am wiring directly to one set of windings, wired in the low speed configuration. A second reason is my suspicion that the switchgear is faulty somehow.
I may indeed end up following this path.
Yes, I would be interested both in how to do this as well as the theory behind how it works. Perhaps it is as simple as even when the switchgear is operated, causing momentary break of main motor with VFD, the VFD is able to tolerate that because it still has a load from the idler motor?
This was the explanation given by the VFD tech. It is my speculation that the amperage overload in this configuration at lower than rated rpm is caused by the higher than expected (for a 1/2hp motor) resistance of that winding configuration. I did not discuss this with the VFD tech but developed that hypothesis after our conversation ended.
I am most appreciative of you helping me try to understand this old and unusual motor.
You’re right about the megger. I’d normally do a check as a general precaution on any old motor, especially if I’ve been fiddling with the wiring. It could be that the VFD is unhappy with the windings at working voltage, for a reason undetectable with a multimeter.
So the VFD is 1ph 230V in, 3ph 230V out, or AT1 type? Have you set the base Hz and rated speed, etc. in parameters for the 600 rpm mode? You might have to trawl through the parameter settings to find one that’s causing trouble.
Reply about whether the VFD/idler system would work for your motor:
“It should cope fine. Mine mainly powers my CNC lathe, but it used to fire up my old Harrison mill without any issue, and my old RPC setup would struggle to get that wound up in top gear, whereas the current setup had no issue.
My setup is an isolating transformer (had issues with the setup tripping the upstream RCD, which would have been very involved getting it changed), which feeds a boost VFD (aka 240V in/400V out), which then goes through a Sine Wave/sinusoidal Filter. I can't remember what side of the filter I have the 2.2 kW idler motor attached though!.
VFD is just left at default settings, although I do keep meaning to reduce the ramp up time. The pole number doesn't actually matter in terms of operation, as it's only use is to show the RPM on the VFD display. The VFD doesn't really care how many poles the motor has.
From memory, it's a 7.5kw VFD. Only things it's currently used for are the CNC lathe (5.5KW spindle, with 1.2kw servos and a 1kw sub spindle), and an old tyre changer.”
Picking up on the comment about pole number, if you’ve put in the wrong value, the VFD will display the wrong speed.
It would be nice to use this get your lathe going with the native speed-change system. You can buy adaptable, stackable switches to replace the old drum switch.
Yes to phase and voltage. I am not familiar with AT1 type designation.
Yes
Thanks for this, although I still don’t have the understanding that I would like.
I don’t believe my VFD has a parameter that allows me to enter number of poles. Is that normally a user entered parameter?
This would be the ultimate goal.
Is that current reactive, or in phase wasting real energy as heat?
If it gets hot, one experiment would be to move all the wires around by one, in case that is important in the way windings cancel.
I assume the other set of six windings all remain open circuit, because they are wound on the same set of poles, it makes a transformer with a load on the secondary.
You had it right here:
This means a VFD should tolerate running a much smaller motor, so higher-resistance windings, than it’s configured for, making the behaviour of yours seem odd.
The idler also provides some inertia, to help start loaded motors.
On the ones I have, yes, for the speed display. What’s the make and model? How are you measuring the 300 rpm?
I have not noticed any wires getting hot, but I have not left it powered on for more than a minute or so. Would there be some other means of testing to answer this question definitively? I don’t understand what is meant by “reactive current “, but perhaps it has to do with your comment below about the transformer?
The other set of windings are unconnected. I am not sure what the implications of the transformer is, sorry.
Does the metal part, or the copper windings of the field windings get hot when 2.3 amps is flowing with no load?
Grubbs1960 said:
I don’t understand what is meant by “reactive current “, ...
A voltage sinewave, across a resistor, causes a current sinewave to flow. The same voltage sinewave across a capacitor or inductor, causes a ±cosine wave of current to flow.
Power is the product of voltage and current, so resistors get hot, but the product of a sinewave and a cosine wave is a sinewave with twice the frequency, so energy comes and goes during every part of the cycle. Only the wires to the power source get hot, as energy circulates, the inductor and capacitor are "reactors" with reactive (unreal) power.
https://en.wikipedia.org/wiki/AC_power#Reactive_power_2
The two sets of coils are isolated electrically, but magnetically coupled through shared poles. That means when one set of windings is driven, there can be voltages on the other set, like the secondary of a transformer. If two secondary connections touch, you may have big currents in the motor, a bit like a shorted turn in a faulty motor. You might also receive a shock from wires to the idle coils.
Thanks for clarifying.
My VFD is an Invertek Optima E3. It will display speed as either Hz or RPM, which is how I determined the 600 rpm windings were maxing out at ~300 rpm. When it reached that speed, the display also flashed decimal points on every LED, which the Invertek technician said indicated max amperage draw.
I will try running a little longer while monitoring this. Thanks for the wiki link as well.
If you haven’t input the number of poles (12), then the drive shouldn’t be able to display an accurate speed, so I assume the output frequency has been limited to 30 Hz in response to the near overload. I’m at a loss to explain how this would help much. For one thing, half speed would reduce fan cooling. VFDs are normally running, or tripped.
All I can say is, Invertek is a very good make and the manual should be intelligible. As well as investigating the motor, have a look at the quick start guide, and maybe the full parameter list, and check the settings are correct. If all is well in both cases, try increasing the current rating gradually.
It could well be that, as you suggested, the old motor draws more current than expected. This would be a combination of low efficiency and low power factor, which is a measure of reactive current draw. The motor plate might list this last quantity as pf, cosphi or cos##\phi##. Can you post details of the motor plate?
I perused my manual again and found no input parameter that would allow me to enter the number of poles. Here’s a link to the manual:(https://admin.invertekdrives.com/as...IN_V1.05 E3 IP20 User Guide V1.04 ENGLISH.pdf)
But there are parameters to enter nameplate frequency and ROM, which I did enter. Perhaps the drive derives the number of poles from these parameters?
See picture of the plate below. None of those are specified.
After 7 minutes of continuous running at no load, the stator temp rose from 22.9C to 23.6C. At the end of this trial, the copper wire of the windings was 25C. This seems reasonable to me, but I have no other experience doing something like this.
I also measured voltage across each of the three terminals of the non-powered windings and got the following values:
19.8 vac across 6 & 14
23 vac across 6&9
4.4 vac across 14 & 9
I have no idea what to make of that or even if it was a meaningful test, but thought it might be indicative of reactive voltage.
That is transformer action. Magnetic coupling between the two independent Dahlander windings.
If 2.3 amps flowed in phase when 230v was applied, then crudely; 2.3*230 = over 500 watts. You would notice 500 watt of heat in the stator windings, so I assume it is a reactive current due to the inductance of the motor windings, which circulates, rather than dissipating energy as heat.
I hope it’s perfectly normal. I was able to set up and turn an approximately 2.5” (525mm) diameter red oak cylinder with amp draw never getting greater than 2.5 amps. I’m becoming more confident that there is probably no issue, at least with this set of windings.
I can’t open this.
I’ve had a look through the manual. I assume this drive was new, and not secondhand, and for the US market, therefore settings were factory default unless changed, and configured for the 60 Hz market:
- P-08: Rated current. This is a guess, and could be tuned by trial and error.
- P-13: Check default 0, general mode. If in pump or fan mode, the drive could be doing the speed limiting you describe as a form of current limit reduction.
- P-10: Rated speed. If you input 600, this is the synchronous speed, not the rated speed. The actual value should be on the plate, and will be somewhere under 600. If you default this value to 0, this disables slip compensation and may be advisable if you don’t know the correct value.
- P-51: Check it’s default 0, vector control mode. Setting 1, V/f mode, may be activating the odd speed limit..
- P-60: Some sort of overload accumulator. Should be disabled 0 by default.
Guineafowl said:
I can’t open this.
Not sure what happened there. Hopefully it will work this time.
Two brass motor nameplates on a wooden surface. The larger plate reads OLIVER MACHINERY CO., GRAND RAPIDS, MICH, U.S.A., with the Oliver logo and BUILT BY. The smaller plate lists 1/2 H.P., 600-1200-1800-3600 R.P.M., 40 C. CONT., 115 VOLTS, 60 CYCLE, 100% LOAD and U.S. PATENT NO. 1587566.
Yes, new drive, configured for US and 60Hz
It is in general mode. I currently have P-08 set at 3.0 amps. I haven’t seen it pull more than 2.5 except when ramping up.
The speeds listed on the plate are 600-1200-1800-3600. Apparently back in the days this motor was made they listed theoretical speed and did not compensate for slip. I did eventually set P-10 to 0.
Verified to be in vector control mode
Yes
As you say, the motor plate doesn’t tell you much. Is it still limited to 30 Hz speed?
One thing that I did notice is that the voltage on the tag reads 220v. I had been thinking it was 230v, which is what I set that parameter to. I haven’t changed that. Maybe I should?
If I wire it to the 600 rpm configuration, yes, it starts pulling higher amperage above about 24 Hz, even with no load. Wired to the 1800rpm configuration, I can run at 60 Hz, actually turn wood, and consistently pull 2.4-2.5 amps. Although this is more than the 2.3 amps shown in the NEC tables for a 1/2 hp motor, I monitored winding temperatures for several minutes and noticed only a slight temperature increase (details in post #52).
I have not tried increasing frequency above 60 Hz. In this configuration.
I briefly wired it as each of the two higher speed configurations (1200 and 1800), but noticed that in both cases the amperage quickly rose above 3 amps so I shut down before it finished ramping up.
Although I can probably just leave it wired in the 1800 rpm configuration and be able to do everything I ever need, part of me wants to keep playing with this and figure out if there’s actually something wrong or if it is operating as designed but that design, because it is not modern, doesn’t behave as a modern 1/2 hp motor would.
I guess the problem you are having is trying to control an induction motor, during the starting process, by using frequency, without reducing the voltage to limit the reactive current. The reactive magnetising current that must flow, is limited by the inductance of the motor windings, and the higher supply frequency.
Applied motor voltage, V, volts. Motor inductance, Lm, henry. Supply frequency, f, Hz.
Motor reactance, XL = 2⋅π⋅f⋅Lm
Reactive current, Ix = V / XL
Keep f high, and V low, to limit the reactive current. You should not be operating it at low frequencies on full voltage, because then the reactive current will be high, so the power factor will be horrible for the VFD.
Select your speed range by choice of Dahlander winding and connection. Then to get closer to the wanted operating speed, use VFD frequency, but stick to say the 50Hz to 100Hz window. Any Dahlander connection switching should be selected before starting, perhaps changing the connection while running, should automatically drop a latched contactor to, or from, the VFD.
It is an induction motor, not a synchronous motor, so slip during start is not a problem, it is a blessing. When starting, there will be no cutter load, so you might hit it with 60 Hz immediately. If the start current is too high while it initially slips, then lower the starting voltage, not the frequency.
When running, keep the operating voltage below the plate specification, stick to the 200v to 220v range.
I agree, set the motor rated voltage to what it says on the plate.
For the 600 rpm mode problem (and maybe the others), It might be worth trying simple V/f mode instead of sensorless vector control. During ramp-up to speed, it will keep the V/f ratio (flux) constant and not try to be too clever. I have had nuisance tripping in SVC mode on an old, heavy motor. Set P-51 to 1, if I remember rightly.
You have to have some ramp-up time (say, 3-5 seconds to avoid impatience) or the drive will trip on overcurrent. Ditto ramp-down, or you’ll get an overvoltage trip.
