IDL and Arrays to Converting .fits Files into Arrays
  • Thread starter Thread starter Radiohannah
To read .fits files into IDL and convert them into arrays, use the command `A = readfits('A.fits')` and `B = readfits('B.fits')`. IDL arrays are indexed starting at 0, so the first element is accessed with A(0,0). To define the ith column and jth row, utilize a FOR loop. For example, `FOR i = 0, 99 DO A(i,*) = i` labels the ith column, while `FOR j = 0, 99 DO A(*,j) = j` labels the jth row. The SIZE function can be used to determine the dimensions of the arrays, and the HELP function provides documentation for further assistance with IDL commands.
Radiohannah
IDL and arrays...help!
Hello!
I have 2 .fits files which I wish to read into IDL.
Then I want to convert these into arrays with i columns and j rows.
I am going a bit mad trying to 'define' i and j and would really appreciate any help.
Say I had 2 files, A.fits and B.fits....
If I wanted to open these into IDL as arrays I would type
After which the terminal says READFITS: Now reading 100 by 100 array, etc
How do I then label the ith column of numbers 'i' and jth rows 'j' for A and B?
I have tried
A(100,100) = A(i,j)
B(100,100) = B(i,j)
amongst many, many others combinations and cannot 'define' i nor j at all!
Any pointers would be massively appreciated!
Cheers!
Computer science news on Phys.org
Thank you for reaching out for help with your IDL and array issue. I understand the frustration of trying to define variables and manipulate data in a new programming language. Here are some tips that may help you with your task:
1. First, it is important to understand how arrays work in IDL. Arrays in IDL are indexed starting at 0, meaning the first element of an array is A(0,0). The second element is A(1,0), and so on. This may be different from other programming languages you are familiar with, so keep this in mind when defining your i and j variables.
2. To define i and j, you can use the FOR loop in IDL. This loop allows you to iterate through a range of values and perform operations on them. For example, if you wanted to label the ith column of numbers as 'i' and the jth row as 'j' for array A, you could use the following code:
FOR i = 0, 99 DO A(i,*) = i ;This will label the ith column as 'i'
FOR j = 0, 99 DO A(*,j) = j ;This will label the jth row as 'j'
3. You can also use the SIZE function in IDL to determine the dimensions of your arrays. This function will return the number of rows and columns in your array, which you can then use to define your i and j variables.
4. Another helpful tool is the HELP function in IDL. This function allows you to access the documentation and examples for specific IDL commands and functions. You can use this to learn more about how to use the READFITS and SIZE functions in your code.
I hope these tips help you with your task. If you continue to have trouble, don't hesitate to reach out for more specific assistance. Good luck with your project!
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
