If A and B are invertible square matrices, there exists
  • Thread starter Thread starter AntiElephant
    Matrices Square
AntiElephant
If A and B are invertible matrices over an algebraically closed field k, show there exists \lambda \in k such that det(\lambda A + B) = 0.
Can anyone agree with the following short proof? I tried looking online for a confirmation, but I wasn't exactly sure how to search exactly for this problem.
Suppose det(\lambda A + B) \neq 0 ~~\forall \lambda \in k
Since det(A^{-1}) \neq 0, then
det(A^{-1}(\lambda A + B)) = det(\lambda I + A^{-1}B) = det(A^{-1}B - (-\lambda)I) \neq 0 ~~\forall \lambda \in kSo -\lambda is not an eigenvalue for A^{-1}B for all -\lambda \in k. i.e. \lambda is not an eigenvalue of A^{-1}B for all \lambda \in k. Since k is algebraically closed this cannot be the case.
Is this okay? I guess it is not necessarily true when k is not algebraically closed?
AntiElephant said:
If A and B are invertible matrices over an algebraically closed field k, show there exists \lambda \in k such that det(\lambda A + B).
? What are you asked to show about det(\lambda A+ B)? You have a subject with no verb!
My bad...early morning. Edited.
You bet it can fail. Take A=[[0,1],[1,0]] and B=[[2,0],[0,1]]. What goes wrong if k is the field of rationals?
I didn't see that last bit about what happens when k is not algebraically closed. It can also fail with the reals. Just construct your matrices so the eigenvalues of A-1B are complex.
Sure. But that's because the reals aren't algebraically closed. The det gives you a real polynomial. If it has no real roots, you are out of luck.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
