If i know velocity, then i know acceleration right?
In simple harmonic motion, the velocity of a particle can be expressed as v = ω√(A² - x²). To find acceleration, one can derive it from the velocity equation by substituting v = dx/dt and integrating to obtain the position function x(t) = A sin(ωt + θ). Once x(t) is determined, acceleration can be calculated as a(t) = dv/dt. The relationship between velocity and acceleration is further clarified through the application of energy conservation principles. Understanding these derivations is essential for analyzing motion in simple harmonic systems.
nemzy
For velocity at a certain particle in a simple harmonic oscillation is the following:
v= w (anguluar frequency) times the squareroot of A^2-x^2
but if i wanted to find the acceleration at a certain particle in a simple harmonic oscillation, i can somehow derive a formula from the above equation right? But how would u derive it?
I know that that V= dx/dt ..and a= (d^2)x/dt^2
ugh, i forgot my calculus, anyone clear it up for me?
thanks
for simple hamonic motion
x = A \sin{( wt-\theta)}
I have no idea what is your equation looks like
v= w (anguluar frequency) times the squareroot of A^2-x^2 :confused:
put it in Latex pls...
The equations for linear harmonic oscillator are something like that
x(t)=A\sin(\omega t+\phi)
v_{x}(t)=A\omega\cos(\omega t+\phi)
a_{x}(t)=-A\omega^{2}\sin(\omega t+\phi)
Then decide what are the initial conditions.And u can determine the 2 unknowns;
Daniel.
v= w \sqrt{A^2-x^2} is that what you trying to say?
OKAY, i don't know where did you get this equation... this is right but ppl usually don't write it this way, if you want to find a(t) from your equation, substitude v=dx/dt, you have
dt=dx/ (w \sqrt{A^2-x^2})
integrate both side and you will havex(t) = Asin(wt+\theta)
after you have x(t), everything should be easy
yes,
v= w \sqrt{A^2-x^2}
is what i am trying to say, so how can u derive a formula from the above equation for acceleration? that is my question
did i just tell you.. do the integral and find x(t)
after you have x(t), v(t)= dx/dt, a(t) = dv/dt
nemzy said:
yes,
v= w \sqrt{A^2-x^2}
The formula is deduced from applying the law of energy conservation.Once u integrate this ODE (using the method prescribed above),you need to diff.2 times wrt to time to find the acceleration.
Daniel.
