If n = 4k+3, does 8 divide n^2-1? Can u check if i did this right?
  • Thread starter Thread starter mr_coffee
mr_coffee
ello ello!
I'm pretty sure this is right but not 100%. Directions are as follows:
GIve a reason for your answer in each of 1-13. Assume that all variables represent integers.
If n = 4k + 3, does 8 divide n^2-1? Here is my answer:
No. n^2-1 = (4k+3)^2-1 = (4k+3)(4k+3)-1 = (16k^2+24k+9)-1 = 16k^2+24k+8 = 16(k+1/2)(k+1). K+1 is an integer but k+1/2 is not necessarily an integer, because 1/2 is not an integer.
Is my reasoning correct? thanks!
:biggrin:
That doesn't work. Failing to write n^2-1 as 8*(some integer) doesn't mean it can't be done.
You got down to:
n^2-1=16k^2+24k+8
just fine. For what values of k is the thing on the right divisible by 8?
well if i divide (16k^2+24k+8)/8 = (3k^2+12k+4)/4.
Is what what you ment? It does divide evenly, and those are all integers still. So can i say, 3k^2+12k+4 is an integer and 4 is an integer because the sums and products of integers are integers?
Something funny happened here, check this carefully.
Why did you factor out 16? You only need to show that it is 8(an integer).
Sorry i had a typo it should have been, (3k^2+12k+4)/2. But I'm lost on what they want.
If n = 4k+3, does 8 divide n^2-1, well yes i just did it above. Nut I'm not sure how that showed 8 is an integer.
THe book did an example like this, but instead of n = 4k+3 its n = 4k+1. They did the following:
n^2-1 = (4k+1)^2 - 1 = (16k^2+8k+1)-1 = 16k^2+8k = 8(2k^2+k), and 2k^2+k is an integer becuase k is an integer an sums and products of integers are integers.
\frac{16k^2+24k+8}{8}=\frac{16k^2}{8}+\frac{24k}{8}+\frac{8}{8}\neq\frac{3k^2+12k+4}{2}
To show n^2-1 is divisible by 8, you can show (n^2-1)/8 is an integer. Equivalently, you can show there exists an integer x where n^2-1=8*x, like they did in your example (no real difference).
My bad! thanks shmoe that makes sense, now I can just show:
\frac{16k^2+24k+8}{8}=\frac{16k^2}{8}+\frac{24k}{8 }+\frac{8}{8} = 2k^2+3k+1 = (k+1)(2k+1). (k+1) and (2k+1) are both integers becuase k is an integer and the sums and products of integers are integers.
Thanks alot! :D
I was tempted to post that not being able to divide by 8 is a handicap in number theory! (but I won't!)
You don't need to factor that: Obviously, 2k2+3k+1 is an integer whether it can be factored or not.
I think it is somewhat simpler just to write 16k2+ 24k+ 8= 8(2k2+3k+1) rather than dividing by 8. The fact that it is a multiple of 8 is sufficient to prove divisibility.
hah I think i am handicapped, I don't enjoy Descrete Math. This course is what is keeping me in Computer ENgineering and not Computer Science.
Thanks for the help!
