jnorman
- 315
when we convert energy to mass, where do the other characteristics of matter, such as charge, come from?
CP violation does not effect charge. Basically the violation means that certain processes involving particles are not exactly the same (for example in decay route) as the equivalent process for antiparticles.kloptok said:In a reaction charge is (almost) always conserved, so the initial charge is equal to the final charge. Do you mean where the charge came from originally? My own deduction is that, since charge is conserved both globally (in the entire universe) and locally, all charge existing in the universe must have been created in some way in the Big Bang. Now, this is probably a greatly simplified picture though, so don't take it too seriously.
I really don't know the details, but I think charge is not conserved in all cases because of violation of CP-symmetry which occurs in some rare cases.
You are right to within flavor changes. A weak interaction can result in a flavor change, so you end up with a particle and anti-particle that aren't each-other's anti-particles. But charge must still be conserved in these.DMT said:I do not yet have a physics degree (working on it currently), but my assumption is that when matter is created from energy, both matter and antimatter particles are created simultaneously, thus conserving charge. For example, when two high energy gamma rays come together they can form an electron-positron pair, which has a net charge of zero. I do not know of any examples where a single charged particle can be created without its corresponding antiparticle, but that could just be due to my novice understanding of the subject.
Rap said:If you do a "gauge transformation" on the Maxwell's equations (i.e. change A to A + del(f) and change V to V+df/dt where f is some function of space and time, and A and V are vector and scalar potentials) then Maxwell's equations stay the same and charge is conserved. Thats where momentum, energy, angular momentum and charge come from.
Phrak said:I'm confused by this. Are you referring to the Dirac relativistic electron?
Classically, Maxwell's equations already contain conservation of charge in the form of the charge continuity equation.
Also, a regauging of (A,V) leaves F unchanged (and indirectly the charge and current). It is the regauging of F that directly leaves the charge unaltered. However, I don't know if there is such a real valued gauge.
Rap said:I should not act like an expert on this, because I'm not. I was not referring to Dirac's equation for the electron, but to electromagnetism in general - i.e. Maxwell's equations. Maxwell's equations express the conservation of charge, the way fluid mechanics equations express the conservation of momentum and energy. But with every conservation law, there is an associated transformation which leaves the equations (Maxwell's, fluid, etc) unchanged. Noether's theorem connects the two concepts, saying that every transformation which leaves the equations invariant corresponds to a conserved quantity. The fact that the fluid equations are invariant under translation corresponds to a conservation of momentum, for example.
Regauging of (A,V) leaves F unchanged is, I think, a way of saying that Maxwell's equations are invariant under a gauge transformation. If regauging of (A,V) did not leave F unchanged, then, I'm guessing, a proof of charge conservation would fail.
In as much as energy is conserved in closed systems in relativity, the mass of a system is also a quantity which is conserved: this means it does not change over time, even as some types of particles are converted to others. For any given observer, the mass of any system is separately conserved and cannot change over time, just as energy is separately conserved and cannot change over time. The incorrect popular idea that mass may be converted to (massless) energy in relativity is because some matter particles may in some cases be converted to types of energy which are not matter (such as light, kinetic energy, and the potential energy in magnetic, electric, and other fields). However, this confuses "matter" (a non-conserved and ill-defined thing) with mass (which is well-defined and is conserved). Even if not considered "matter," all types of energy still continue to exhibit mass in relativity. Thus, mass and energy do not change into one another in relativity; rather, both are names for the same thing, and neither mass nor energy appear without the other. "Matter" particles may not be conserved in reactions in relativity, but closed-system mass always is.
K^2 said:Phrak, rest mass vs inertial mass. Learn the difference. Rest mass is NOT conserved. Inertial mass IS conserved. Two entirely different subjects, and you MUST specify which one you are talking about.
That is a very old convention. Nobody uses it. In any modern article, m means rest mass because it is a Lorentz invariant quantity.Rap said:I think by convention, m means the relativistic mass, and rest mass m0
K^2 said:E \neq mc^2
Because by convention, m means rest mass. It is true that
E = m_{rel}c^2
But that's not the same thing. The equation for rest mass is different.
E^2 = p^2c^2 + m^2c^4
K^2 said:That is a very old convention. Nobody uses it. In any modern article, m means rest mass because it is a Lorentz invariant quantity.
Open ANY particle physics paper from the past 50 years. You will never see a single m0. All mass is invariant mass in these papers.Rap said:That is easily debatable if not wrong. Google "rest mass" and you will not find a reference which uses m for rest mass, all use m sub zero. I doubt you can find any reference which introduces m as the rest mass without explicitly stating such in order to eliminate confusion with the conventional m sub zero. Regardless, Einstein's statement E=mc^2 is the signature equation of special relativity, seen every where, and to ingenuously imply that it is an error or incomplete is misleading.
Then your statement is plainly wrong. CoM frame mass of an atom that has emitted a photon changes without matter creation/annihilation process. (The photon has zero rest mass.)Phrak said:Forget about relativistic mass. It just confuses things.
Studiot said:Hello, jnorman.
I think this is a very good question an I for one would be interested to read an adequate answer.
I am no expert in nuclear and (fundamental) particle reactions, but I do know that mass disappears in some and energy appears; what I am not aware of are any reactions where energy disappears and new particles appear instead.
However perhaps the experts in this field will lay out and discuss some of these?
K^2 said:Then your statement is plainly wrong. CoM frame mass of an atom that has emitted a photon changes without matter creation/annihilation process. (The photon has zero rest mass.)
This is an extraordinary claim. Your emitted photons are interesting objects with definite momentum.
Relativistic mass is conserved. Invariant mass is not. If you don't want to talk about relativistic mass, you are just wrong.
