If we convert energy to mass, where does charge come from?
The discussion centers on the question of where charge originates when energy is converted to mass, exploring the relationship between energy, mass, and charge within the context of physics. Participants delve into theoretical aspects, conservation laws, and the implications of particle interactions, including reactions involving matter and antimatter.
  • Some participants question the origin of charge when energy is converted to mass, suggesting that charge must also be accounted for in such transformations.
  • Others argue that charge is conserved in reactions, implying that the total charge before and after must remain equal, and propose that all charge in the universe may have originated from the Big Bang.
  • A participant mentions that while charge is generally conserved, there are exceptions due to CP violation, which they believe does not affect charge conservation directly.
  • One participant introduces Noether's theorem, stating that conservation laws arise from symmetries in physical equations, linking charge conservation to gauge transformations in electromagnetism.
  • Another participant, without a physics degree, speculates that matter and antimatter are created simultaneously during energy conversion, thus conserving charge, and expresses uncertainty about the existence of charged particles created without their antiparticles.
  • Some participants discuss the nuances of particle interactions, such as weak interactions leading to flavor changes, and how these processes still adhere to charge conservation despite complexities.
  • There is confusion regarding the application of gauge transformations and their implications for charge conservation, with participants seeking clarification on the relationship between Maxwell's equations and conservation laws.
Participants express a range of views on the origin and conservation of charge, with no consensus reached. While some agree on the conservation of charge in reactions, others highlight exceptions and complexities that challenge a straightforward understanding.
The discussion includes various assumptions about the nature of charge and its conservation, as well as the implications of particle interactions that may not be fully resolved. The relationship between gauge transformations and charge conservation remains a point of contention and exploration.
jnorman
when we convert energy to mass, where do the other characteristics of matter, such as charge, come from?
In a reaction charge is (almost) always conserved, so the initial charge is equal to the final charge. Do you mean where the charge came from originally? My own deduction is that, since charge is conserved both globally (in the entire universe) and locally, all charge existing in the universe must have been created in some way in the Big Bang. Now, this is probably a greatly simplified picture though, so don't take it too seriously.
I really don't know the details, but I think charge is not conserved in all cases because of violation of CP-symmetry which occurs in some rare cases.
CP violation does not effect charge. Basically the violation means that certain processes involving particles are not exactly the same (for example in decay route) as the equivalent process for antiparticles.
There is a theorem called Noether's theorem that says every time you can do a transformation which does not affect the physics equations, you will have something conserved. If you do a translation in space, the physics equations stay the same, and momentum is conserved. If you do a translation in time, the physics stays the same and energy is conserved. If you do a rotation in space, the physics stays the same and angular momentum is conserved. If you do a "gauge transformation" on the Maxwell's equations (i.e. change A to A + del(f) and change V to V+df/dt where f is some function of space and time, and A and V are vector and scalar potentials) then Maxwell's equations stay the same and charge is conserved. Thats where momentum, energy, angular momentum and charge come from.
I do not yet have a physics degree (working on it currently), but my assumption is that when matter is created from energy, both matter and antimatter particles are created simultaneously, thus conserving charge. For example, when two high energy gamma rays come together they can form an electron-positron pair, which has a net charge of zero. I do not know of any examples where a single charged particle can be created without its corresponding antiparticle, but that could just be due to my novice understanding of the subject.
You are right to within flavor changes. A weak interaction can result in a flavor change, so you end up with a particle and anti-particle that aren't each-other's anti-particles. But charge must still be conserved in these.
For example, suppose you have a free neutron decaying into proton and electron. Electron isn't a part of neutron, and so it must be created. But if you create an electron and a positron, the net charge is not conserved if you also change neutron into proton. So instead, a neutrino and anti-neutrino are created. One of the down quarks in the neutron then weakly interacts with neutrino, exchanging electrical charge. Down quark becomes an up quark, and neutrino becomes an electron.
This is actually an example of a CP violation. Weak processes do not conserve CP.
There is also the bit where matter can change mass without particles or anti-particles being created, but then there isn't a need for charge to be created/destroyed either.
I'm confused by this. Are you referring to the Dirac relativistic electron?
Classically, Maxwell's equations already contain conservation of charge in the form of the charge continuity equation.
Also, a regauging of (A,V) leaves F unchanged (and indirectly the charge and current). It is the regauging of F that directly leaves the charge unaltered. However, I don't know if there is such a real valued gauge.
I should not act like an expert on this, because I'm not. I was not referring to Dirac's equation for the electron, but to electromagnetism in general - i.e. Maxwell's equations. Maxwell's equations express the conservation of charge, the way fluid mechanics equations express the conservation of momentum and energy. But with every conservation law, there is an associated transformation which leaves the equations (Maxwell's, fluid, etc) unchanged. Noether's theorem connects the two concepts, saying that every transformation which leaves the equations invariant corresponds to a conserved quantity. The fact that the fluid equations are invariant under translation corresponds to a conservation of momentum, for example.
Regauging of (A,V) leaves F unchanged is, I think, a way of saying that Maxwell's equations are invariant under a gauge transformation. If regauging of (A,V) did not leave F unchanged, then, I'm guessing, a proof of charge conservation would fail.
Yes, that's true--or at least we're not in disagreement. It's just that it's an indirect regauging. And without assuming the electric and magnetic fields are the derivatives of the more primative fields A and V, then charge is still conserved.
1) There may be a direct regauging, F <-- F' = F + dZ, where Z is the unknown gauge field, that leads to charge conservation.
2) Regauging A=(A,V) via A <-- A' + d\phi, conserves F as well as charge. One example is transformation to the Lorentz gauge.
thanks for the responses, but i am still quite confused on this. not just about charge. forexample, the original energy has no physical attributes, but somehow that energy manages to manifest a variety of characteristics once it is transformed into matter - ie, charge is one of those features - but also, now the energy has become, eg, an electron in some cases with a whole integer charge, and also become a variety of types of quarks which have partial charge, flavor, color, etc, etc. where do all those things come from, and what is going on that allows energy to generate both quarks of different varieties as well as fundamental particles like electrons? i know my question is absurdly layman, so please respond as you might to someone with mild retardation... thanks.
Hello, jnorman.
I think this is a very good question an I for one would be interested to read an adequate answer.
I am no expert in nuclear and (fundamental) particle reactions, but I do know that mass disappears in some and energy appears; what I am not aware of are any reactions where energy disappears and new particles appear instead.
However perhaps the experts in this field will lay out and discuss some of these?
On the misconception: mass converted to energy
http://en.wikipedia.org/wiki/Mass#Mass_and_energy_in_special_relativity"
In as much as energy is conserved in closed systems in relativity, the mass of a system is also a quantity which is conserved: this means it does not change over time, even as some types of particles are converted to others. For any given observer, the mass of any system is separately conserved and cannot change over time, just as energy is separately conserved and cannot change over time. The incorrect popular idea that mass may be converted to (massless) energy in relativity is because some matter particles may in some cases be converted to types of energy which are not matter (such as light, kinetic energy, and the potential energy in magnetic, electric, and other fields). However, this confuses "matter" (a non-conserved and ill-defined thing) with mass (which is well-defined and is conserved). Even if not considered "matter," all types of energy still continue to exhibit mass in relativity. Thus, mass and energy do not change into one another in relativity; rather, both are names for the same thing, and neither mass nor energy appear without the other. "Matter" particles may not be conserved in reactions in relativity, but closed-system mass always is.
Phrak, rest mass vs inertial mass. Learn the difference. Rest mass is NOT conserved. Inertial mass IS conserved. Two entirely different subjects, and you MUST specify which one you are talking about.
Don't just complain; commit yourself. Why don't you explain how you think this
[tex]E=mc^2[/tex]
really means
[tex]E + mc^2 = constant[/tex]
or whatever it is you have in mind.
[tex]E \neq mc^2[/tex]
Because by convention, m means rest mass. It is true that
[tex]E = m_{rel}c^2[/tex]
But that's not the same thing. The equation for rest mass is different.
[tex]E^2 = p^2c^2 + m^2c^4[/tex]
I think by convention, m means the relativistic mass, and rest mass m0
That is a very old convention. Nobody uses it. In any modern article, m means rest mass because it is a Lorentz invariant quantity.
OK, I see where my use of [itex]E = mc^2[/itex] was misunderstood.
Forget about relativistic mass. It just confuses things.
Mass is the magnitude of the Lorentz convariant 4-vector of momentum, [itex]p^\mu[/itex], from which [itex]m^2c^4 = E^2 - p^2c^2[/itex] immediately follows.
This continues to hold for a system of particles where the domain is special relativity but not general relativity so it's not really true anyways except in a narrow sense. In the center of mass frame,
[tex]E =mc^2 \ .[/tex]
That is easily debatable if not wrong. Google "rest mass" and you will not find a reference which uses m for rest mass, all use m sub zero. I doubt you can find any reference which introduces m as the rest mass without explicitly stating such in order to eliminate confusion with the conventional m sub zero. Regardless, Einstein's statement [tex]E=mc^2[/tex] is the signature equation of special relativity, seen every where, and to ingenuously imply that it is an error or incomplete is misleading.
Open ANY particle physics paper from the past 50 years. You will never see a single m0. All mass is invariant mass in these papers.
Then your statement is plainly wrong. CoM frame mass of an atom that has emitted a photon changes without matter creation/annihilation process. (The photon has zero rest mass.)
Relativistic mass is conserved. Invariant mass is not. If you don't want to talk about relativistic mass, you are just wrong.
Whilst all you experts are busy debating mass changes due to relativity could you spare a moment to consider my question in post #11
I thought this thread was all about nuclear and particle reactions such as power our nuclear power stations.
Thanks
Studiot said:
Hello, jnorman.
No expert here, but I think:
1. Gamma ray turning into an electron/positron pair
2. I think firing a fast electron into a nucleon may produce an extra neutron from the energy of the electron (ie. you end up with more mass then you started with and less KE then you started with)
This is an extraordinary claim. Your emitted photons are interesting objects with definite momentum.
This is an extraordinary claim. Your emitted photons are interesting objects with definite momentum. Isn't the uncertainty in momentum in the order their energy? What is the expectation value, <p>?
Do you have a citation for this theory or is it your own?
The photon has non-zero relativistic mass. Relativistic mass of a photon is p/c=hf/c^2 where f is frequency, h is Planck's constant. This is the same amount of relativistic mass lost by the emitting body. Suppose the emitting body is at rest before emission. Its relativistic mass (and rest mass) is m0. After emission, its relativistic mass is m'. Conservation of energy says m0 c^2=m' c^2+hf. Dividing the energy equation by c^2 gives m0=m'+hf/c^2 - i.e. relativistic mass is conserved.
Thank you, zincshow and welcome.
Where does charge come from...
nobody really knows, anymore than we know why charge is quantized...you can get a synopsis of what we do know here:
http://en.wikipedia.org/wiki/Electric_charge
but it does not explain the origin of charge. Once here, it's conserved, but why it's here is unknown as is the magnitude. We can decribe charge characteristics and make predictions about outcomes, but no generally accepted answer exists as to the origin...exept that everything popped out of a bang...big or otherwise...
The reason why we have charge, or mass, or the forms of energy we do..kinetic,potential,etc... or the speed of light, or space and time, are unknown.
One answer is that all these physical entities are rather precariously balanced, so in other universes where some of the entities were substantially different, life (we) could not exist, because for example, such a universe could never forms stars, planets, atoms, etc.
They are all related (mass, charge, energy...)
The Universe we live within started at the Big Bang. Therefore, At the start, time = 0, all the forces of Nature were one. Therefore it is safe to say, all the properties were the same.
This is why we can have a "unifying theory of everything".
  • · Replies 16 ·
  • · Replies 44 ·
  • · Replies 24 ·
