If you could see gravity what do you think it would it look like?
  • Thread starter jt3213
  • Tags
    Gravity
In summary: The sound waves propagate out from the bell, and as they do, they pull on objects in their path. This is why you can hear things further away, and also why objects closer to the bell are pushed away.In summary, In Bob's opinion, gravity is a fluid-like force that is weaker the higher you are in the universe. It is easier to see around a dark object because the darkness is a visual representation of how strong the gravity is.
jt3213
If you could see gravity what do you think it would it look like? The trampoline, or fabric example doesn't seem right to me. I guess I've always imagined gravity as a 'fluid' for lack of a better term. I just imagine the gravitational field expands in all directions creating a sphere of gravity around the object. What are your opinions on this? Does my idea sound like a correct visualization?
Astronomy news on Phys.org
jt3213,
Your visualization "the gravitational field expands in all directions creating a sphere of gravity around the object." is exactly correct.
Bobbywhy
Thanks
What bobby said is correcting. Just adding in, the point of visualizing it as a fabric or trampoline isn't that it is supposed to look like that. That is more of a cross-section view showing one half of the gravitational field/influence the object has on it. It's more difficult and confusing for a viewer if they try to draw a full sphere of grid-lines encircling a solid object to illustrate how that object warps those lines due to the overlap.
There is also the option with a cross-section then to use instead of grid lines a solid object such as, like you said a trampoline. but if you tried to have the same influence on all angles of an object using a solid fabric you wouldn't be able to see the object inside it for the visualization.
I'll try in helping you visualise gravity. :)
First, the basics. Gravity is a weak force, but has a long range. An electron, being such a small particle, still can exert its gravitational influence (albeit very weak) to the very end of the observable universe (if we had a sensitive enough instrument to measure it, we can!).
Now to the visualizing part. I assume you ask this question from the perspective of an observer on earth. From this perspective, "gravity" "reduces in its intensity" as we go skywards. Since you talk about "fluids", I'll try to help you visualise this on the basis that, the stronger the gravity is, the "darker" it is to see around. If you had the sense to visualize gravity in this sense, what you would see would be similar to what a fish would see in a murky pond. the deeper you are, the murkier and darker it gets. So on the surface of the earth, you wouldn't be able to see a thing, but, as you go higher, things start clearing up and when you reach "space", you start seeing things. In this case, the level of "darkness" corresponds to the strength of gravity.
What it means actually is that, from the perspective of a person on the surface of the earth, gravity reduces gradually from the surface as you move skywards.
For Newtonian 1/r^2 gravity it will work just fine. With the weird effects of general relativity like gravity waves you won't have much luck. I don't know any simple model that works for that.
Please don't misconstrue what I'm about to say, but, this has bothered me for decades.When I visualize a spinning sphere, in a space/ time fluid like matrix, that supposedly causes gravity, I see a vortex develop, at the top and bottom of the sphere, due to differentials in the speed of rotation at higher and lower latitudes, that's just how fluid dynamics works. Even considering the helical path of the object through this matrix, I see a vortex behind it. If "frame dragging" is the cause, what am I missing? Is the frame dragging in all possible directions all at once? Thanks in advance.
Bob
I'm not familiar with such a concept. Are you referring to spacetime as described by General Relativity?
Thank you, yes That was the idea as explained by a Prof. @ Cornell ,I met @ Watkins Glen, few years back.. Or he didn't describe it properly/ I misconstrued his explanation ? Thanks in advance.
GR doesn't describe spacetime as a fluid, so I don't know what happened. :olduhh:
You could also imagine gravity waves as sound waves emanating from a point source in a medium of air (ignoring the inertia of air molecules).
My bad, I believe the term he used, was a friction-less super fluid, if that's any different, a description.
I believe certain aspects of General Relativity are analogous to a super fluid, but as far as I know it's just an analogy, not a real description.
Many thanks Drakkith... So the mental semantics, was in my interpretation, of his analogy..
If you're interested, you can see the following link for more analogies: http://arxiv.org/abs/gr-qc/0005091
Re: “If you could see gravity what do you think it would it look like?”
From here on earth, I think it would look like the Aurora Borealis everywhere; dynamic and fluctuating wave forms with its luminosity varying in direct proportion to its intensity. Much like the lines of magnetic flux as seen using iron filings but, ever moving and changing.
I developed a method to visualize electromagnetic (EM) fields from studying books by Feynman and Weinberg, and papers by Dicke, among others, while working with different types of antennae at different frequencies.
First I visualize a small section with splines in multiple dimensions shaped somewhat like a shepherds crook or a stretched integral sign. The 'curl' at the 'top' varies by signal strength (intensity) and 'curls away' from the radiation spheroid. E and H are perpendicular to each other and normal to the direction of propagation of the field. Sheaves of splines form lobes.
Expand or shrink this section as the problem dictates in as many dimensions as required. I used to keep all the dimensions perpendicular until I learned more differential geometry. Also, I now replace splines with manifolds visualizing manifold 'surfaces' to represent fields in my mind.
I use various modifications of this technique to visualize other fields. It is very helpful when introducing an object -- target in military jargon -- such as an aircraft intercepting radar lobes, a meteor entering the Earth's gravity field, atmosphere, magnetosphere; and solar storms and sunspots.
[Edit: Describing my personal method to visualize fields. I do NOT imply that gravity and EM fields are the same. Thanks.]
1) What is gravity and why is it important?
Gravity is a natural phenomenon that causes objects with mass to attract one another. It is important because it is what keeps our planet and other celestial bodies in orbit, and it also plays a crucial role in many aspects of our everyday lives, such as keeping us grounded and allowing us to walk on Earth.
2) How does gravity affect light and other forms of energy?
Gravity affects all forms of energy, including light. The force of gravity can cause light to bend as it passes through different materials or objects, which is known as gravitational lensing. It can also affect the wavelength and frequency of light, which is known as gravitational redshift.
3) If we could see gravity, would it appear as a force or a physical object?
If we could see gravity, it would likely appear as a force rather than a physical object. This is because gravity is a fundamental force of nature, similar to other forces like magnetism and electricity. However, some theories suggest that gravity may be carried by particles called gravitons, but these have yet to be directly observed.
4) How would seeing gravity change our understanding of the universe?
Seeing gravity would greatly enhance our understanding of the universe. It would allow us to visualize the effects of gravity on a larger scale, such as the gravitational pull between galaxies or the curvature of space-time caused by massive objects. It could also potentially help us develop new theories and technologies related to gravity.
5) Is it possible for us to ever see gravity?
At this time, it is not possible for us to directly see gravity. This is because gravity does not interact with light, which is how we perceive and see things. However, scientists continue to study and explore ways to indirectly observe and measure the effects of gravity through various experiments and technologies.
  • Astronomy and Astrophysics
  • Thermodynamics
