If you saturated the air with salt, it becomes dielectric?
Vaporizing salt and dispersing it in the air raises questions about its impact on air's dielectric properties. The discussion centers on whether the presence of salt can transform air into a conductor or a dielectric medium, particularly under low to medium voltage conditions. It is suggested that while salt may influence the air's insulating properties, the presence of fresh air pockets could still impede conductivity. The core inquiry revolves around whether sufficient salt can enhance the air's permittivity, making it more conducive to electrical flow. Ultimately, the feasibility of using vaporized salt to alter air's dielectric characteristics remains uncertain.
Strangeline
say you vaporized salt and threw it in the air. Would that be enough to turn that volume of air dielectric or would the minute pockets of fresh air in among the salt molecules still block low-med voltage
Hrmm. Are you thinking that the salt causes the air to be less of an insulator, or did you actually mean a dielectric?
I mean, with enough salt in the air, could you pass the voltage of a 9v battery through the air... so i guess I am asking if this would, in effect, turn a pocket of air into a conductor, and in the extreme case, a dielectric
A dielectric is an insulator usually used in a capacitor.
I think you are asking if you can increase the permittivity of the air by throwing vaporized salt in the air?
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
