Improper integral help (trig sub?)
The discussion revolves around solving the improper integral from 0 to 1 of (4r*dr)/sqrt(1 - r^4). The original poster struggles with the calculation, initially arriving at -2, but later realizes that the correct answer is π. Key issues identified include the necessity of changing the limits of integration when performing variable substitution and ensuring the correct relationships between trigonometric functions are applied. Participants emphasize that the substitution was valid, but the oversight in limits led to the incorrect result. Ultimately, the correct approach confirms that π is indeed the right answer for the integral.
Badcommando
I have been bashing my head against this problem for a couple of hours now and cannot for the life of me figure it out. i am able to get AN answer but when i check it with my calculator i always get pi
integral from (0, 1) of:
i know the equation is undefined at r = 1 so:
lim t --> 1 of the integral (0, t) of (4r*dr)/sqrt(1 - r^4)
by trig subsitution:
sin(x) = sqrt(1-r^4)
cos(x) = r^2
deriving implicitly gives:
-sin(x) = 2rdr
-2sin(x) = 4rdr
so i end up with:
integral (0, t) of (-2sin(x))/(sin(x))
which gives me the answer as -2
maybe my calculator is wrong? or more likely I am making some stupid mistake/overlooking something.
When you do a variable substitution you need to change the limits of integration as well.
So you need to integrate from the x-value when \sin(x) = 1 to where \sin(x) = 0 since when r = 0, \quad \sqrt{1-r^4} = 1 and when r = 1, \quad \sqrt{1-r^4}= 0.
\pi is the correct answer.
try r = [cos(θ)]^1/2
also with your sub i get r^4 = cos(x)
His substitution is fine. He just forgot to change the limits.
Also \sin(x) = \sqrt{1-\cos^2 (x)} so in his case r^4 = \cos^2 (x) \Rightarrow r^2 = \cos(x)
\pi is the correct answer. So you need to integrate from the x-value when sin(x) = 1 to where sin(x) = 0 since when r = 0 sqrt(1-r^4) = 1 and when r = 1 sqrt (1-r^4) = 0.
yup, youre right i was making a stupid mistake, i just totally left out the last step.
i just plugged arccos(r^2) in for theta after integrating and got pi as the correct answer. thanks for all of your help.
Was just pointing out there is an easier sub where he may have not run into arithmetic mistakes. Like his claim: sin(x) = sqrt(1-r^4) -> cos(x) = r^2
What is wrong with that claim? Looks right to me.Edit:
Think a right angled triangle with hypotenuse 1 and the opposite side of the angle x as sqrt(1-r^4).
This means that sin(x) = sqrt(1-r^4).
From Pythagoras the last side (y) must satisfy sqrt(1-r^4)^2 + y^2 = 1^2 --> 1 - r^4 + y^2 = 1 --> r^4 = y^2 --> y = r^2.
Now cos(x) = y/1 = r^2.
ah oops i was doing sin(x) = sqrt(1-r^4) ⇒ sin^2(X) = 1 – r^4 ⇒ r^4 = sin^2(x) – 1 ⇒ r^4 = cos^2(x)
and just noticed that he didn't have a ^2 on his cos(x) my bad.
  • · Replies 105 ·
  • · Replies 19 ·
  • · Replies 22 ·
