Solve Improper Integral: \int_{-3}^{1}\frac{x}{\sqrt{9-x^{2}}}
In summary, the conversation discusses the integral of x/sqrt(9-x^2) and how to solve it using the substitution method. The attempt at a solution involves introducing sine, which leads to the incorrect answer of 0. The correct solution is -2.8.
darkchild
155
[tex]\int_{-3}^{1}\frac{x}{\sqrt{9-x^{2}}}[/tex]
Let f be continuous on the half-open interval (a, b] and suppose that
[tex] \lim_{x \to a^{+}} |f(x)| = \infty[/tex]. Then
[tex]\int_{a}^{b}f(x) dx = \lim_{ t \to a^{+}}\int_{t}^{b}f(x)
dx[/tex]
= \lim_{ t \to -3^{+}}\int_{t}^{1}\frac{x}{\sqrt{9-x^{2}}}
[/tex]
[tex] u = 9 - x^{2} [/tex]
[tex] du = -2x dx [/tex]
[tex] \lim_{ t \to -3^{+}}\int_{t}^{1}\frac{x}{\sqrt{9-x^{2}}}
= \lim_{ t \to 0^{+}}-\frac{1}{2}\int_{t}^{8} u^{-1/2} du
=\lim_{ t \to 0^{+}}-u^{1/2}|_{t}^{8}
=-\sqrt{3sin(1)} + \lim_{ t \to -3^{+}}\sqrt{3sin(t)}
=-1.588840129 + ?[/tex]
I get 0 for the limit, but according to Maple and my graphing calculator, that does not give the correct value for this integral. The correct value is approximately -2.8. May I please have some guidance as to what may have went wrong?
[/tex]
I don't understand that step where you introduce sine. You should just get:
[tex]
=-\lim_{t \to 0^+}(\sqrt{8} - \sqrt{t})
= 0 - 2\sqrt{2}
= -2\sqrt{2}
\approx -2.8
[/tex]
Oh, god, I made an incredibly stupid mistake...Thank you.
haha, it happens. no worries.
FAQ: Solve Improper Integral: \int_{-3}^{1}\frac{x}{\sqrt{9-x^{2}}}
What is an improper integral?
An improper integral is an integral where either the upper or lower limit of integration is infinite, or the integrand function has a vertical asymptote within the interval of integration. In this case, the integrand has a vertical asymptote at x=3, which makes it an improper integral.
How do you solve an improper integral?
To solve an improper integral, we first need to rewrite it as a limit of a definite integral. In this case, we can split the integral into two parts: \int_{-3}^{0}\frac{x}{\sqrt{9-x^2}}dx + \int_{0}^{1}\frac{x}{\sqrt{9-x^2}}dx. Then, we can use the substitution method to solve each part, taking the limit as the upper limit approaches the point of discontinuity at x=3.
What is the substitution method?
The substitution method is a technique used to simplify integrals by substituting a variable with a new one. This is particularly useful when dealing with improper integrals, as it allows us to rewrite the integral in a form that can be easily evaluated.
Can this integral be solved without using the substitution method?
Yes, it is possible to solve this integral without using the substitution method. However, the substitution method is the most efficient and straightforward way to solve it. Other methods, such as partial fractions or trigonometric substitutions, can also be used, but they may be more complicated.
What is the final solution to this improper integral?
The final solution to this improper integral is \frac{1}{2}(3\sqrt{2}+2).
