In coordinate bond, why doesn't the H^+ atom get a negative charge?
In summary, the H^+ atom does not get a negative charge in a coordinate bond because it shares electrons with nitrogen, effectively having just one electron. This is due to the fact that the lone pair on nitrogen donates electron density to the proton, forming a covalent bond where both electrons come from one atom. Therefore, the resulting bond is still covalent and not ionic. The correct reaction is NH3 + H^+ → NH4^+, where all four N-H bonds are equivalent and the formal positive charge is distributed evenly across the four hydrogens.
HCverma
82
In a coordinate bond, why H^+ atom don't get the negative charge? as an example [NH4]^+
If we split [NH4]^+, we get NH3 + H^+. In NH3, N and 3H atoms have completed their octet and H^+ accepts the lone pair of electrons from the N, As we know H^+ has no any electrons but a proton. If it receives two electrons from the N, out of the two electrons, one electron neutrals the H atom so H^+ changes to H and another is an extra electron, so the H atom changes to H^- ( here H^+ ion does not share an electron with N but it completely receives from the N). So it NH4^+ should be NH3^+-H^-
Chemistry news on Phys.org
It would be NH32+. How much energy would you need to get two electrons from NH3 and how would the remaining electrons be arranged?
I assume this happens in water? Keep in mind that you don't actually get H+. You get H3O+.
Hint: count charges on all nucleons, count all electrons, that gives you the charge on the molecule. Doesn't matter where the electron exactly is.
If you count two electrons on H, you will be missing one on N.
you mean to say N will show 7 electrons and it has 8 protons. For this reason, here N^+ meant one extra proton?
H2O + HCl = H3O+ + Cl-
NH3 + HCl = NH4+ + Cl-
Am I Correct?
H atoms sometimes do get negative charges, in compounds with elements less electronegative than H.
Such as LiBH4
More like one missing electron, but yes, 8 protons in nucleus and 7 electrons would mean N+.
I got it but what my problem is that if H+ receives two electrons, why does not it change to H- because it has two electrons now out of two electrons, one is for one proton, making the atom a neutral and another is an extra atom, making the atom negative. could you explain, please?
It doesn't have two electrons, it shares these electrons with nitrogen, effectively having just one of them.
There is no H+ that would receive two electrons.
How could it share electrons with N because N completely donates its lone pair of electrons to H+?
What do you mean by 'there is no H+ that would receive two electrons'? Could you explain, please?
I don't understand what is unclear.
You asked "if H gets two electrons, then X" and asked why X is not the case. Simple: Because H doesn't get two electrons.
Why do you believe this? It isn’t true.
I think @HCverma is thinking of the fact that the lone pair on N donates electron density to the proton, forming a dative bond (a covalent bond where both electrons come from one atom). However, this type of bond is still covalent (electrons are shared). He seems to think it will be ionic, in which case you’d have
$$NH_3 +H^+\rightarrow NH_3^{2+} +H^-$$
due to charge conservation, as @mfb mentioned before in post 2.
Edit: for clarity’s sake, what really happens is:
$$NH_3 +H^+\rightarrow NH_4^+$$
where all 4 N-H bonds are equivalent (and the formal positive charge is distributed evenly across the four hydrogens).
Could you please explain your point below in more detail?
'where all 4 N-H bonds are equivalent (and the formal positive charge is distributed evenly across the four hydrogens)'
I'm not sure what else there is to explain. All of the bonds in NH4+ are equivalent (equal length/equal strength). The Lewis structure has a formal positive charge on the nitrogen, but in reality, the positive charge is shared equally by the hydrogens.
Likes HCverma
Ok, then where the positive charge on the nitrogen comes from? As I know positive charge means a proton and an atom shows only positive charge if it has an electron less in numbers than the protons at the nucleus of the atom.
It is exactly the same for a molecule - count all protons in all nuclei, count all electrons, see what total charge you get.
N has 7 protons and 7 (own electrons) + 3 (from 3 H atoms) = 10 electrons. So there are 3 more electrons, still why N atom has a positive ion on it? Please explain
You asked not about ammonia, but about NH4+ produced by adding a proton to ammonia.
Sometimes I wonder if you are not just trolling.
The electrons from the hydrogen atoms are not located at the nitrogen atom.
Ok, just let me clear. Then where does the proton come on N in NH4+? Which atom or atoms add a proton to N? Could you explain, please?
You wrote an example of how it can happen by yourself:
Likes Bystander
No, my question is that from where does N get extra proton so that it changes to N+?
If N got an extra proton it would become O+. The ammonia molecule gains a proton (in the form of a hydrogen ion) to become NH4+. This has 11 protons and 10 electrons, so has a single positive charge.
How is it possible? N has 7 protons and 7 electrons. N will get 3 electrons to full fill its octet. So the total electrons are 10 but N still has 7 protons because protons. are permanent. Atoms only can gain or lose electrons not protons.
You know atoms can't get protons, yet you ask where does N gets the extra proton from?
It will also get 3 protons (in the case of NH3) or 4 protons (in the case of NH4+). For simplicity, in the case of NH3, N will share 3 of its electrons with 3 hydrogen atoms (each with 1 electron and 1 proton). It doesn't take the hydrogens' electrons from them (at least not entirely--see below). If it did, then you would write ammonia's formula as N3-(H+)3. Covalent bonds involve sharing of electrons. The 3 electrons from the hydrogens serve to complete the nitrogen's octet, but they don't count toward the formal charge. For the formal charge, each covalent bond counts as one electron.
So for NH4+, there are 4 covalent bonds around nitrogen; therefore there are 8 (4x2) valence electrons satisfying the nitrogen's octet, but only 4 valence electrons counting toward nitrogen's formal charge. Add the 2 non-bonding 1s electrons and you have 6 total electrons assigned to nitrogen for the sake of formal charge. Since nitrogen has 7 protons, the formal charge on nitrogen is +1.
(Caveat: there is some polarity in the N-H bond. That is, a given electron is more likely to be found around the nitrogen in an N-H bond than the hydrogen. However, it is far from being a complete charge transfer.)
Likes HCverma
There are 11 protons and 10 electrons in NH4+, therefore the molecule has a single positive charge.
Two of the electrons are in the n=1 shell of nitrogen, the other 8 form 4 pairs that are shared between nitrogen and one hydrogen each. If you sum the charges like that you have 6 electrons at the nitrogen atom with its 7 protons.
Since the proton is a little-bitty thing, it do not have enough mass to pull the electron to it more than some other not so bitty thing.
(the language could use some refinement)
  • #31
Protons attract electrons by charge, not mass. The electrical force is enormously greater than the gravitational force between electrons and protons - a factor of about 1039.
  • #32
I understand everything except this point 'Add the 2 non-bonding 1s electrons and you have 6 total electrons assigned to nitrogen for the sake of formal charge.' Add to which atom the 2 non-bonding 1 s electrons? Could you simplify your point, please?
  • #33
No, add as in 4+2=6. You have 4 electrons from nitrogen participating in bonding in NH4+. You have 2 electrons in the 1s orbital of nitrogen (these electrons are not valence electrons: they don't participate in bonding). You add 4+2 to get 6 electrons assigned to nitrogen. Since nitrogen has 7 protons (this is always true--otherwise it's not nitrogen), its formal charge is 7-6 = +1.
FAQ: In coordinate bond, why doesn't the H^+ atom get a negative charge?
1. Why doesn't the H+ atom get a negative charge in a coordinate bond?
The H+ atom does not get a negative charge in a coordinate bond because it is already a positively charged ion. In a coordinate bond, the H+ atom is sharing its lone pair of electrons with another atom, but it still retains its positive charge.
2. How does the H+ atom maintain its positive charge in a coordinate bond?
The H+ atom maintains its positive charge in a coordinate bond because it is donating its lone pair of electrons to another atom. This electron donation does not change the charge of the H+ ion, but it does allow it to form a bond with another atom.
3. Can the H+ ion form a coordinate bond with any atom?
No, the H+ ion can only form a coordinate bond with atoms that have a lone pair of electrons available for donation. This includes atoms such as oxygen, nitrogen, and sulfur.
4. What is the difference between a coordinate bond and a covalent bond?
A coordinate bond is a type of covalent bond where one atom donates a lone pair of electrons to another atom. In a covalent bond, both atoms contribute electrons to form a shared electron pair.
5. How does the formation of a coordinate bond affect the overall charge of a molecule?
The formation of a coordinate bond does not affect the overall charge of a molecule, as the total number of electrons in the molecule remains the same. However, it can affect the distribution of charge within the molecule, as the atom receiving the lone pair of electrons may become slightly more negative while the atom donating the electrons may become slightly more positive.
10K
