In hot pursuit, Agent Logan of the FBI
  • Thread starter Thread starter hitemup
    Hot
Agent Logan of the FBI must cross a 1200-meter river with a current of 0.80 m/s while rowing at 1.60 m/s and running at 3.00 m/s to minimize crossing time. The optimal strategy involves rowing at an angle of 24.9 degrees upstream and running 104 meters along the bank, resulting in a total crossing time of 862 seconds. The calculations involve determining the rowing and running times based on the angle and the distances covered. The discussion highlights the importance of correctly accounting for the river's current in the rowing calculations. The final solution emphasizes the need for symbolic representation of variables during calculations for clarity.
hitemup
[/B]
In hot pursuit, Agent Logan of the FBI must get directly across a 1200-m-wide river in minimum time. The river's current is 0.80 m/s, he can row a boat at 1.60 m/s, and he can run 3.00 m/s. Describe the path he should take(rowing plus running along the shore) for the minimum crossing time, and determine the minimum time.
x = v*t
[/B]
2 <---vRiver= 0.80 m/s
m
Let the angle between dashes and slash be x.
The agent must be at the dot when he's done with rowing and running.
The distance between the dot and the point he arrives after rowing(bold dashes) is y.
Rowing time is: t1
Running time is: t2So the equations are:
1200 = 1.60*(sinx)*t1
y = (1.60*(cosx) - 0.80)*t1
y = 3.00 * t2
t1 + t2 = 750/sinx + y/3.00
t1 + t2 = (750/sinx) + (1.60*(cosx) - 0.80)*1200/(3*1.60*(sinx))
In short,
t1 + t2 = 550/(sinx) + 400cot(x)
After taking derivative,
-550(cosx)/(sin2x) - 400/(sin2x) = 0
The angle I got from this is 136.7 degrees.
180-136.7 = 43.3 degrees is the angle between the river current and the boat.
But according to my book, the correct answer is the following.
"Row at an angle of 24.9 degrees upstream and run 104m along the bank in a total time of 862 seconds."I guess my thinking on this question is wrong. Any ideas how to draw the vectors here?
I solved the problem and I got the result from the book. I suggest keeping your variables as symbolic during the calculations, and using their numerical values just at the end. (In that way you get rid of all those numbers and you get pretty neat expressions). Give names to the quantities:
##d=1200##m
##v_{row}=1.60##m/s
##v_{riv}=0.80##m/s
##v_{run}=3.00##m/s
Apart from that, you should use the angle defined as you want it in the answer. With that, the velocity of the boat can be written as:
##\vec{v}=(v_{row}\cos\theta,v_{row}\sin\theta-v_{riv})##
I consider your approach is correct, just revise your calculations using what I just told you.
At the end of the calculation you will notice that the value of the angle does not depend on the width of the river. (If you replace the numbers from the beginning it is impossible to notice that)
you add 0.8 not subtract it xd
Not quite.
He will row partly against the current, so 1.60*(cosx) - 0.80 is correct. The error is that the distance to run is never negative, so it should read y = |(1.60*(cosx) - 0.80)|*t1.
And since there is no benefit in arriving upstream of the target, we can simplify that to y = -(1.60*(cosx) - 0.80)*t1.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
